Replacing Interior Chrome Door Handle
dagall
Have an '07 and the passenger side door handle chrome is peeling off and actually cut my wife's finger. Has anyone had to replace one of these? Directions or is there a shop manual showing the sequence I could look at? Thanks
Edited by dagall
Use this guide to get the front door panel off:
http://www.paulstravelpictures.com/Ford-Edge-Door-Panel-Removal-Speaker-Replacement-Guide/index.html
Then, according to the manual (supplied pics are too small to be useful IMHO):
Interior Door Handle
Removal and Installation
  1. Remove the door trim panel. For additional information, refer to Section 501-05 .
  1. NOTE: Front door shown, rear door similar.
    Disconnect the interior door handle from the door window regulator and motor assembly.
    Remove the interior door handle.
    • Disconnect the interior door handle actuating cable from the interior door handle.
    • Remove the interior door handle.
  1. To install, reverse the removal procedure.
  • 1 year later...
  • 8 years later...
The same thing happened to be on my 2013 Fusion. It was on the inside so I just sanded it down and it was ok and not visible.
