How to Change Speedometer from KPH to MPH
Just purchased a previously Canadian-owned 2013 Edge SEL. The odometer is displaying miles, but the speedometer has the large numbers in KPH, with MPH in small numbers (see picture below).
I've read through the owner's manual but don't find how to change the speedometer to MPH in the outer ring of large numbers.
I was driving a canadian car in england for a year (km/h instead of miles), and I have friends who owns US Car in Canada (miles instead of km/h). You will get used to the conversion pretty quickly and you should be able to follow the speed limits using km/h (for instance, 30 miles is about 50 km/h, 60 miles is about 100, etc).
Personnally, I don't think it is worth spending the money to change the speedometer. Also, I believe the cruise control should be able to display your speed in miles on the left screen when you set it up.
  • 4 weeks later...
  • 2 months later...
