The trans in my 2008 AWD has been chattering or clunking going at a slower speed, maybe around 40 mph as it tries to upshift. If I press the pedal down hard - no more problem. So last night as I was beginning to go forward after a traffic light turned green, the engine reved very high and the car was sluggish to get moving - almost like the trans was slipping - but once I reached about 30 mph, it operated normally. But started very slowly every time I had to stop. The little wrench indicator was too. This morning... car ran fine. No service light.
What is going on??
I read on this forum about a OSS(?) sensor in the trans that has a reputation for going bad, but my symptoms don't sound exactly the same. How can I read the codes?
Sorry to hear about the problems, possible that the trans is starting out in a higher gear from stop (there is a TSB related to that). That would be a Transmission Range sensor going bad.
Codes can be read with an OBDII reader, and major auto parts stores should be able to read them for you for free.
Related TSBs:
http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=179533 / http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=180543
http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=171494
http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=176597
http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=136827
Edited by WWWPerfA_ZN0W
Not good to let the motor rev and the transmission slip while getting up to 30 mph. A trick to get the computer thinking again is to shut of the motor allowing the code to reset. Then slowly put the vehicle in reverse and allow the car to backup a few feet, put it in drive, move forward and then repeat. You should hear/feel the transmission clunk between drive and reverse. Carefully accelerate in drive and it should be fine unless there is a hard failure.
I have done this a couple of times with success. I know I will eventually have to have something serviced and replaced but both times this happened, the conditions were different leading me to believe I may have two issues.
Good luck...
Related TSBs:
Any chance you have a TSB for the 2008? All of these are for different years.
Not happy. So I got the car back a week later. The day after we picked it up, I noticed that the car is still jerking between 40 & 60 mph with gentle acceleration. I brought it back to Ford. They told me that coil #5 needs replacement. They wanted to charge me a little over $350.00 to do it. I bought the coil and am in the process of replacing it right now. I have doubts that this could cause the kind of shifting privileges I am experiencing.
  • 4 months later...
