Battery Change How
1duFos
Good day, I want to change the battery in my 2010 Edge. Part of the battery is under the front cowl. In order to remove the battery will I need to remove or move the lid of the air box which looks to be in the way to slide and lift the battery out. Any help would be appreciated.
Thanks
Unless you've already bought the battery (and if you're in the states) just take it to Advance or some other auto parts store and they'll change it for you in 10 minutes at no extra charge.
If you need to take off the air filter box the top should come off by pressing in on the tabs at the front and/or rear.
