Pothole damage?
Hit a pothole with my right front wheel and since then there has been a very faint knocking sound here and there when making sharp turns. No alignment issues etc.
Just had her maintenance this past Saturday and nothing was caught but then again I never mentioned the pothole...
If I inspect the area myself what should I be looking for in particular?
Typically they will not check closely as part of routine maintenance, and even then there is a threshhold under which they will say "normal wear & tear, no concern". I would have steering AND alignment checked next time you go in for service.
That sounds about right. Will do. Thanks!
