2016 Edge rear wiper
Rear windows are hard to keep clean.
Before replacing the blade (and running into the same problem with a different blade), try cleaning this one first. Run a wet rag over the rubber and clean the crap that builds up on them. You'll be surprised as to how much gunk will be on your rag afterwards.
I use Rain x on the rear window to slow the dirt buildup.
Driving around the Midwest for the last few weeks, through snow melted from salt and slush, has worn off all my Rain X and mine streaks as well.
Keeping the rubber clean is the key to keep it from streaking. (mostly).
Edited by enigma-2
You know, I don't see why a 14" blade designed for the 14-15 MKX wouldn't work on your 16. Does the 16 look physically different? My 09 is just a simple flat, 14" snap-on blade.
I looked for a Rain-X for your 2016 and read that the Rain-X blade has Rain-X in the blade. Believe I'll try this on my next change.
