Comprehensive List of Possible Forscan Mods?
ben senise
19 minutes ago, redden18 said:
TPMS screen - not possible. It has only started with 2015 Edge where there is a TPMS for individual tire. On your Edge it is only a dash light and you have to find out yourself which tire runs flat.
Digital speedo - not possible either.
As for climat on right IPC - you actually do not gain much, it is only temp and fun controls. I have it and I barely use it.
Initially, climat screen was by default on 11 to ether 12 or 13 MY vehicles, but later Ford removed it.
I think you may get all thise features by IPC firmware update but it is very time consuming and you have to know what you are doing.
The other thing I dont know when Edge has been moved from CGEA 1.2 to CGEA 1.3 electrical architecture. If it still on 1.2 some of the features may not be possible even with firmware update.
Thanks for getting back to me friend!
In this case, it becomes something more complex and risky, so I prefer to end the search for climate control here.
Anyway, thanks for the help so far!
 Hello, how are you?
This time I need an answer. I have read everything about the firmware, or at least I think so, and I am still not sure
if I can update or not, it is possible... anyway, I am very confused. I am posting some images to see if you can help me.
Thanks everyone.
Sorry if I already answeredCapturadepantalla(9).thumb.png.d338f94b350cbf45fa78d9698ff2d5d3.png
  • 1 year later...
I bought the vgate linker OBD AND ALSO BOUGHT a standard license for one year forscan software but i cant find ANYWHERE  the function that retrieve the keyless entry code for the doors as i seen it in many videos in youtue
Can any one tell me the reason why i dont have this feature??
Could you elaborate on what are you trying to achieve? what youtube videos?
being a computer guy, finally getting a vehicle with a computer and way to eff around with was peak curiosity.  So far i have done the following using Forscan:
Police Mode locked gear shift                    - Enabled
Double Honk when running and exiting     - Disabled
Turn Signal flashes when tapped                - 6 (increased from the default 3)
Seat Belt Chimes                                          - Disabled
Door Ajar Chimes                                         - Disabled
Key Fob Remote Window Close                  - Enabled (only remote window open was enabled)
Police Dark Car Mode                                  - Enabled
Silent Mode on Left Cluster Screen            - Added
SiriusXM as a media source                        - Disabled
SiriusXM Travel Link                                     - Disabled
Climate Section on Right Cluster Screen    - Enabled
Sync3 Splash Screen                                   - Raptor (changed from the default Ford logo)
Auto Door Relock                                          - 30 Seconds (lowered from 45 seconds)
the only other things i was going to do in Forscan at this time from what i read were:
- add the option to disable DRL into the IPC and enable the ability to do disable (being in Canada its mandatory to be enabled)
- remove the turn signal from always being illuminated and only being active when turning (i think i saw someone do this on an earlier page - pg6 maybe)
i updated Sync3.0 to Sync3.4 using Synupdater3 from Cyanlabs....such a nicer look and feel.
i was also scanning through https://www.fmods.net/ but haven't yet done any mods or app installs but some do intrigue me.
Edited by koof
