PatrickGuinalia Posted August 23, 2024 Report Share Posted August 23, 2024 19 minutes ago, redden18 said: TPMS screen - not possible. It has only started with 2015 Edge where there is a TPMS for individual tire. On your Edge it is only a dash light and you have to find out yourself which tire runs flat. Digital speedo - not possible either. As for climat on right IPC - you actually do not gain much, it is only temp and fun controls. I have it and I barely use it. Initially, climat screen was by default on 11 to ether 12 or 13 MY vehicles, but later Ford removed it. I think you may get all thise features by IPC firmware update but it is very time consuming and you have to know what you are doing. The other thing I dont know when Edge has been moved from CGEA 1.2 to CGEA 1.3 electrical architecture. If it still on 1.2 some of the features may not be possible even with firmware update. Thanks for getting back to me friend! In this case, it becomes something more complex and risky, so I prefer to end the search for climate control here. Anyway, thanks for the help so far! Quote Link to comment Share on other sites More sharing options...
ronkeras Posted October 6, 2024 Report Share Posted October 6, 2024 Hello, how are you? This time I need an answer. I have read everything about the firmware, or at least I think so, and I am still not sure if I can update or not, it is possible... anyway, I am very confused. I am posting some images to see if you can help me. Thanks everyone. Sorry if I already answered Quote Link to comment Share on other sites More sharing options...
Muhanad Posted October 31 Report Share Posted October 31 I bought the vgate linker OBD AND ALSO BOUGHT a standard license for one year forscan software but i cant find ANYWHERE the function that retrieve the keyless entry code for the doors as i seen it in many videos in youtue Can any one tell me the reason why i dont have this feature?? 1 Quote Link to comment Share on other sites More sharing options...
redden18 Posted November 3 Report Share Posted November 3 On 10/31/2025 at 9:13 AM, Muhanad said: I bought the vgate linker OBD AND ALSO BOUGHT a standard license for one year forscan software but i cant find ANYWHERE the function that retrieve the keyless entry code for the doors as i seen it in many videos in youtue Can any one tell me the reason why i dont have this feature?? Could you elaborate on what are you trying to achieve? what youtube videos? 1 Quote Link to comment Share on other sites More sharing options...
koof Posted December 6 Report Share Posted December 6 (edited) being a computer guy, finally getting a vehicle with a computer and way to eff around with was peak curiosity. So far i have done the following using Forscan: Police Mode locked gear shift - Enabled Double Honk when running and exiting - Disabled Turn Signal flashes when tapped - 6 (increased from the default 3) Seat Belt Chimes - Disabled Door Ajar Chimes - Disabled Key Fob Remote Window Close - Enabled (only remote window open was enabled) Police Dark Car Mode - Enabled Silent Mode on Left Cluster Screen - Added SiriusXM as a media source - Disabled SiriusXM Travel Link - Disabled Climate Section on Right Cluster Screen - Enabled Sync3 Splash Screen - Raptor (changed from the default Ford logo) Auto Door Relock - 30 Seconds (lowered from 45 seconds) the only other things i was going to do in Forscan at this time from what i read were: - add the option to disable DRL into the IPC and enable the ability to do disable (being in Canada its mandatory to be enabled) - remove the turn signal from always being illuminated and only being active when turning (i think i saw someone do this on an earlier page - pg6 maybe) i updated Sync3.0 to Sync3.4 using Synupdater3 from Cyanlabs....such a nicer look and feel. i was also scanning through https://www.fmods.net/ but haven't yet done any mods or app installs but some do intrigue me. Edited December 6 by koof 2 Quote Link to comment Share on other sites More sharing options...
Iroga Posted 14 hours ago Report Share Posted 14 hours ago On 6/30/2021 at 7:36 PM, omar302 said: Figured out 2 more mods on the MKX Cluster: Change the Brake light icon: 720-06-02 xxXx xxxx Changed X to 0 will show "BRAKE" as the light, 8 will make a brake icon. You can see the different brake light in the below images compared to the images in my previous posts above. Add "Drive Control" selector in vehicle settings. This will also remove the adaptive steering selection from the driver assist menu. Yes, the Edge does not have "Adaptive dampers", so this will only affect the "Adaptive Steering", but the benefit comes in the cluster showing "Sport mode" with red semi circles when "Sport" mode is selected. Also if Comfort mode was selected, blue semi circles will come up. 720-07-01 xxXx xxxx xxxx Changed X to 4 enables "Drive Control". "0" disables it. Edge 2019, Titanium. 720-07-01 xx X x xxxx xxxx Changing the X value to 4 enables the "Drive Control" feature. Setting it to "0" disables it. Didn't work. The red and blue semicircles didn't appear. Quote Link to comment Share on other sites More sharing options...
omar302 Posted 12 hours ago Report Share Posted 12 hours ago 1 hour ago, Iroga said: Edge 2019, Titanium. 720-07-01 xx X x xxxx xxxx Changing the X value to 4 enables the "Drive Control" feature. Setting it to "0" disables it. Didn't work. The red and blue semicircles didn't appear. Did you change the actual instrument cluster (IPC) to the Lincoln/Mondeo/EU model? The circles only work on the Lincoln/Mondeo/Eau cluster. 1 Quote Link to comment Share on other sites More sharing options...
