Comprehensive List of Possible Forscan Mods?
ben senise
i think its a wire today it says the alignment is 0.00 i did push one side off the post then checked the pid for alignment and it was 0 then was like lets see if it changes if i place it back and it did not without driving the vehicle. should i place this info in a different thread?
On 8/20/2026 at 6:07 AM, gjkrisa said:
can any one help me figure out how to update the vin? top photo is new working c-cm from a mkx. second smaller photo is my oem c-cm module. my vin is
2FMTK4AP3FBC40639
5LMTJ3DH5HUL21198 this is the mkx vin
I have re-read your post and noticed that the VIN you posted for the vehicle if the new CCM is actually a Lincoln MKC, not MKX. The MKC is totally different, maybe the CCM is not compatible regardless of loaded software and calibration.
4 hours ago, Summers22 said:
Thank you,  @omar302 do you know the value to disable the seatbelt location pop-up?
It has been a few years, but I remember that with the values I posted I would not get the pop-up on startup, it would only pop up if a rear seat belt becomes unbuckled during the drive cycle.
During startup, only a small grey "icon" (not a pop up) will show with the number of buckled seatbelts.
23 minutes ago, Summers22 said:
Thank you. So those values made it go away, I read it as uou added that feature, my mistake.
You are correct that I did add the feature. However, as I was playing around with the values, some values would make the pop up come up at startup (what you are facing right now), but the final values I kept don't have the pop up with only the grey icon showing and the pop up I'd a rear seatbelt is unbuckled.
@omar302thanks for the help! Interesting observation though. When I went to enter those forscan changes I tried to use all those combinations in the 80s and the program kept telling me that was an invalid choice. It gave me a warning box and stopped at 51% and then I had to restore that code. When I went and checked after doing all that, somehow it must have took because my seat belt warning display is no longer popping up. Have you ever seen anything like that? I kind of know what I'm doing because I've been doing forscan for about 12 years so this is the first time I've ran into something like that. Bambi mode and ASS both took just fine.
4 minutes ago, omar302 said:
@Summers22
Glad it eventually worked as you wanted. And yes, I have seen cases were ABD doesn't write or gives errors.
Check what are the current values to confirm if the values were written fully or not.
It automatically switched back tonthe as-built data, which is confusing to me that it did that, but still took the change.....
  • Confused 1
yeap i have had similar removing forward collision not work warning. put in a code that may work said it didn’t but did. and then my adaptive cruise started working till july 4th said i had to adjust horizontal alignment.
not sure if it was the code or just started to work. of course i reset everything as i couldn’t figure out how to get the alignment right as when i moved it up or down it didnt change but found i need to work on left right when i get the time to remove the bumper.
