gjkrisa Posted August 22 Report Share Posted August 22 i may have been thinking of horizontal wrong i thought that was up and down not left right. Quote Link to comment Share on other sites More sharing options...
gjkrisa Posted August 22 Report Share Posted August 22 i think its a wire today it says the alignment is 0.00 i did push one side off the post then checked the pid for alignment and it was 0 then was like lets see if it changes if i place it back and it did not without driving the vehicle. should i place this info in a different thread? Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 22 Report Share Posted August 22 On 8/20/2026 at 6:07 AM, gjkrisa said: can any one help me figure out how to update the vin? top photo is new working c-cm from a mkx. second smaller photo is my oem c-cm module. my vin is 2FMTK4AP3FBC40639 5LMTJ3DH5HUL21198 this is the mkx vin I have re-read your post and noticed that the VIN you posted for the vehicle if the new CCM is actually a Lincoln MKC, not MKX. The MKC is totally different, maybe the CCM is not compatible regardless of loaded software and calibration. 1 Quote Link to comment Share on other sites More sharing options...
gjkrisa Posted August 22 Report Share Posted August 22 might be right as i can not find where it said the one i bought was the upgraded part. here is oem next to used mkc. they seem very close so i believe i had the right info. Quote Link to comment Share on other sites More sharing options...
gjkrisa Posted August 22 Report Share Posted August 22 ok searched EJ7T-9G768-AF on ford.com says only works for mkc i do think this is reason. Quote Link to comment Share on other sites More sharing options...
Summers22 Posted August 29 Report Share Posted August 29 Anyone know what to change to delete the all seatbelts pop up on the left side of the cluster on start-up? Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 29 Report Share Posted August 29 1 hour ago, Summers22 said: Anyone know what to change to delete the all seatbelts pop up on the left side of the cluster on start-up? Maybe try the ABD configuration I had with the MKX cluster? Not sure if it would be the same or not. Check this post. 2 Quote Link to comment Share on other sites More sharing options...
Summers22 Posted August 30 Report Share Posted August 30 Thank you, @omar302 do you know the value to disable the seatbelt location pop-up? Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 30 Report Share Posted August 30 4 hours ago, Summers22 said: Thank you, @omar302 do you know the value to disable the seatbelt location pop-up? It has been a few years, but I remember that with the values I posted I would not get the pop-up on startup, it would only pop up if a rear seat belt becomes unbuckled during the drive cycle. During startup, only a small grey "icon" (not a pop up) will show with the number of buckled seatbelts. 1 Quote Link to comment Share on other sites More sharing options...
Summers22 Posted August 30 Report Share Posted August 30 Thank you. So those values made it go away, I read it as uou added that feature, my mistake. Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 30 Report Share Posted August 30 23 minutes ago, Summers22 said: Thank you. So those values made it go away, I read it as uou added that feature, my mistake. You are correct that I did add the feature. However, as I was playing around with the values, some values would make the pop up come up at startup (what you are facing right now), but the final values I kept don't have the pop up with only the grey icon showing and the pop up I'd a rear seatbelt is unbuckled. Quote Link to comment Share on other sites More sharing options...
Summers22 Posted August 31 Report Share Posted August 31 @omar302thanks for the help! Interesting observation though. When I went to enter those forscan changes I tried to use all those combinations in the 80s and the program kept telling me that was an invalid choice. It gave me a warning box and stopped at 51% and then I had to restore that code. When I went and checked after doing all that, somehow it must have took because my seat belt warning display is no longer popping up. Have you ever seen anything like that? I kind of know what I'm doing because I've been doing forscan for about 12 years so this is the first time I've ran into something like that. Bambi mode and ASS both took just fine. Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 31 Report Share Posted August 31 @Summers22 Glad it eventually worked as you wanted. And yes, I have seen cases were ABD doesn't write or gives errors. Check what are the current values to confirm if the values were written fully or not. 1 Quote Link to comment Share on other sites More sharing options...
Summers22 Posted August 31 Report Share Posted August 31 4 minutes ago, omar302 said: @Summers22 Glad it eventually worked as you wanted. And yes, I have seen cases were ABD doesn't write or gives errors. Check what are the current values to confirm if the values were written fully or not. It automatically switched back tonthe as-built data, which is confusing to me that it did that, but still took the change..... 1 Quote Link to comment Share on other sites More sharing options...
gjkrisa Posted August 31 Report Share Posted August 31 yeap i have had similar removing forward collision not work warning. put in a code that may work said it didn’t but did. and then my adaptive cruise started working till july 4th said i had to adjust horizontal alignment. not sure if it was the code or just started to work. of course i reset everything as i couldn’t figure out how to get the alignment right as when i moved it up or down it didnt change but found i need to work on left right when i get the time to remove the bumper. Quote Link to comment Share on other sites More sharing options...
Summers22 Posted Sunday at 12:30 AM Report Share Posted Sunday at 12:30 AM Dumb request, but on my 23 Bronco Sport, the auto high beams could be set to slowly ramp up brightness. Anyone figure that one out? Quote Link to comment Share on other sites More sharing options...
Summers22 Posted Sunday at 12:53 AM Report Share Posted Sunday at 12:53 AM Found it in BdCYM, plain english, search ramp and changed from disabled to enabled. 1 Quote Link to comment Share on other sites More sharing options...
Summers22 Posted 16 hours ago Report Share Posted 16 hours ago Well that didn't work......also my auto start stop reverted back to not working. This is the most finicky vehicle I have ever made forscan changes on....Auto Stop Start eliminator ordered. Quote Link to comment Share on other sites More sharing options...
