Ford Edge Forum
  • 0
colorado
powertrain, abs and traction control illuminate at the same time
Question
notice there some topic for that but nothing works so far, started with those coming on and then the abs and traction would go off and on. after restarting the car, all light would be gone and after come back. but now its always there. transmission got power and shifting ok, no difference notice. did check all my abs sensor with a multi meter(3 were around 1.41 to 1.47 and the other one was at 2.1), don't know if it could be a problem. also check all my tone ring, no damage found. like i said the car run fine. what would be my next options. thanks for any help.
Share this post
Link to post
5 answers to this question
  • 0
Read the codes and stop guessing. Could still be a bad sensor/loose sensor wire.
Share this post
Link to post
  • 0
to read those code, you probably need to go to the dealer, cause my odb2 is not reading anything.
Share this post
Link to post
  • 0
ForScan enables you to read all/most DTCs from all/most modules in Ford vehicles.
Share this post
Link to post
  • 0
ok, will try it, thanks
Share this post
Link to post
  • 0
A dirty or bad MAF sensor will toss out those codes.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
