ccutaia1 Posted November 10, 2018 Report Share Posted November 10, 2018 Hi, I want to tap into my dimming rear view mirror and connect my radar detector. 1st how does the plastic remove from the mirror so I can get to the connections, 2nd what color wires can I tap into for power and ground? Quote Link to comment Share on other sites More sharing options...
TheGrossman Posted November 13, 2018 Report Share Posted November 13, 2018 Try this post: P.S. I hope the above link works! Have never tried to copy and paste a link before. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 12, 2018 Report Share Posted December 12, 2018 I pulled this off the 150 forum. Ok for those with the power mirror and front camera. Here is how to tap into the harness. Use the white connector facing the drivers side to tap for radar detector. Black wire for ground. Solid yellow wire for power. It is the second yellow wire under the black one. See pics. Oh and the plastic cap doesn't use any clips. It has a male plunger type holder on each side of the plastic piece that covers the lower part of the mirror. Pull firmly straight down on both sides and it will pop out. The top piece is held in place by the bottom piece. You just squeeze on both sides of the top piece near the mirror stud and it will pull off. Make sure to put the lower piece back on first when reinstalling. Then just pop the top piece back on. 1 Quote Link to comment Share on other sites More sharing options...
cmantis Posted December 12, 2018 Report Share Posted December 12, 2018 You can also use a tap on #23 in the fuse box up under the drivers side. I used that for my dashcam but now I want to add a wire for power when off for parking mode with low voltage cut off if anyone has any ideas (prefer to tap a fuse if possible). Quote Link to comment Share on other sites More sharing options...
ccutaia1 Posted December 13, 2018 Author Report Share Posted December 13, 2018 On 12/12/2018 at 4:01 AM, enigma-2 said: I pulled this off the 150 forum. Ok for those with the power mirror and front camera. Here is how to tap into the harness. Use the white connector facing the drivers side to tap for radar detector. Black wire for ground. Solid yellow wire for power. It is the second yellow wire under the black one. See pics. Oh and the plastic cap doesn't use any clips. It has a male plunger type holder on each side of the plastic piece that covers the lower part of the mirror. Pull firmly straight down on both sides and it will pop out. The top piece is held in place by the bottom piece. You just squeeze on both sides of the top piece near the mirror stud and it will pull off. Make sure to put the lower piece back on first when reinstalling. Then just pop the top piece back on. OK, so if I have the mirror and camera which I do, the wire color/connection is the same as the video? Quote Link to comment Share on other sites More sharing options...
ccutaia1 Posted December 13, 2018 Author Report Share Posted December 13, 2018 3 hours ago, ccutaia1 said: OK, so if I have the mirror and camera which I do, the wire color/connection is the same as the video? I tried to remove the camera cover and it is not coming off as you had said it would, are you sure? Quote Link to comment Share on other sites More sharing options...
ccutaia1 Posted December 13, 2018 Author Report Share Posted December 13, 2018 3 hours ago, ccutaia1 said: I tried to remove the camera cover and it is not coming off as you had said it would, are you sure? The video on YouTube is spot on. The top piece has to come off first, push forward pull down. The bottom piece does not pull straight down if you do you may wind up pulling down the whole mirror assembly as I did. You need to take the ears left and right on the top of the bottom piece once the top piece is removed and push them out to release the tabs shown in the video then pull down. Alls well that ends well, everything is back together and working with no damage. Quote Link to comment Share on other sites More sharing options...
