jesus_lomor Posted December 28, 2018 Report Share Posted December 28, 2018 Hi all, I am looking for this cooling fan connector (Not the module) but I couldn't see any part number on it. Does anyone knows how to find it? I have asked in some stores, but they all say that I have to buy the complete cooling fan assembly, and I really don't want to do that. I gess this happened because of a loose terminal. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 29, 2018 Report Share Posted December 29, 2018 Ford should have this available in their catalog, I would think. RockAuto.com is showing a radiator fan relay connector (and also a motor connector): https://www.rockauto.com/en/catalog/ford,2007,edge,3.5l+v6,1434490,electrical-connector,radiator+fan+relay+connector,18946 but it is not the right part. 1 Quote Link to comment Share on other sites More sharing options...
jesus_lomor Posted December 29, 2018 Author Report Share Posted December 29, 2018 8 hours ago, WWWPerfA_ZN0W said: Ford should have this available in their catalog, I would think. RockAuto.com is showing a radiator fan relay connector (and also a motor connector): https://www.rockauto.com/en/catalog/ford,2007,edge,3.5l+v6,1434490,electrical-connector,radiator+fan+relay+connector,18946 but it is not the right part. Thanks man, I took a look on the web page but unfortunately couldn't find it. I'll keep digging. But, thanks for the link, it has really nice information. Quote Link to comment Share on other sites More sharing options...
GM1 Posted August 28, 2019 Report Share Posted August 28, 2019 Hi, I have the exact same thing, my connector from the relay to the fan looks like this (see picture), How did you fix it? Thanks Quote Link to comment Share on other sites More sharing options...
handfiler Posted August 28, 2019 Report Share Posted August 28, 2019 This is a common issue on a lot of Fords. The fan has a high current draw when it is in good shape and it gets worse when the fan gets older. The plugs are typically the first area to experience a conductive loss and that results in higher resistance which causes the meltdown. Make sure the replacement connections are clean and tight when you replace them. It would also be a good idea to check the current draw of the fan once the connection is repaired to make sure it isn't exceeding the fuse/wiring ratings. Quote Link to comment Share on other sites More sharing options...
GM1 Posted August 29, 2019 Report Share Posted August 29, 2019 Thank you for your quick response, Any idea where can I get such connector? Quote Link to comment Share on other sites More sharing options...
BlackEdition Posted April 20 Report Share Posted April 20 On 12/29/2018 at 10:17 AM, WWWPerfA_ZN0W said: Ford should have this available in their catalog, I would think. RockAuto.com is showing a radiator fan relay connector (and also a motor connector): https://www.rockauto.com/en/catalog/ford,2007,edge,3.5l+v6,1434490,electrical-connector,radiator+fan+relay+connector,18946 but it is not the right part. On 8/28/2019 at 4:28 PM, GM1 said: Hi, I have the exact same thing, my connector from the relay to the fan looks like this (see picture), How did you fix it? Thanks I have the same exact problem as your image. My fan connector got fried and now im driving without the fans working. I looked around for the complete wiring harness for the radiator fans but couldn't find any, so I guess the only way is to cut the wire and replace the plug. Anyone knows the part number for the plug alone (or the entire wiring for the fans)? I couldn't find any: https://www.rockauto.com/en/catalog/ford,2013,edge,3.7l+v6,1504152,electrical-connector,radiator+fan+motor+connector,2556 Quote Link to comment Share on other sites More sharing options...
BlackEdition Posted April 21 Report Share Posted April 21 After hours of hunting around, I finally found the little bugger! $1 for a connector and a bit of wire isn't bad to fix a major cooling issue. I think cutting the burnt connector and attaching the new one should fix it as unplugging it and plugging it back on made the fans work again, but that only lasted about 3 days. I doubt my entire fan wiring or the controller is compromised. https://aliexpress.com/item/1005002760807461.html This is the only connector that I think needs replacing, I just need someone to confirm before I buy and wait 1-2 weeks to get here? (2013 Ford Edge Sport V6 3.7L, without tow package) Quote Link to comment Share on other sites More sharing options...
Cade McClain Posted Monday at 05:12 PM Report Share Posted Monday at 05:12 PM For anyone domestic looking for these connectors, I had luck with these ones on eBay. All three of the OEM connectors were totally fried on my 2008 edge so I rewired both the fan sides and relay side with these, seems to have fixed my issues. Hope this helps. https://www.ebay.com/itm/318672639358 Quote Link to comment Share on other sites More sharing options...
