Tail light swap?
You would have some difficulty making the turn signals work.  The 2010 had the turn signals and brake lights sharing the same red bulb and therefore the same single power wire from the turn signal switch.  2011+ has separate amber turn signals which used a wire separate from the brake light wire.  You would have to figure some way to separate the turn signal power from the brakes.  That would probably involve bypassing the brake light power through the turn signal switch and running separate brake light wires to each side.
  • Thanks 1
  • 1 year later...
