Adaptive Cruise Control Does not Disengage on Accel
Mikey
I'm baffled why Ford decided to allow adaptive cruise control (not sure if this is true in non-adaptive mode?) to remain engaged when I step on the accelerator pedal?  Stepping on either pedal should disengage CC and instantly assert my authority over the machine.    E.G. if I'm following another vehicle at a "4 bar" setting and need to speed up slightly in order to change lanes it won't let me unless I reduce the bars or manually disengage via button or touching the brake.
I would surmise that this defect is correctable in software.  How can I change it?
What M/Y? - consider putting that in your profile signature line and save being asked again.
My 2017 Sport does not behave like that.
I always have the follow distance set at 1 bar, and when I put my foot on the gas the distance control deactivates, release the gas and the speed and adaptive/distance control go back to normal.
Edited by 1004ron
I get some acceleration but then I feel the brake coming on so it's definitely "fighting" me.
Could it be that you're getting too close or approaching too rapidly and the anti-collision is cutting in, but if that's not it, yours is defective.
What's your M/Y owners manual say?
Edited by 1004ron
Definitely not anti-collision (but that's another gripe I have for exiting traffic in front of me!)
Yes, with no car in front of me I can accel to faster then let off accel pedal and it goes back to the set-point speed.   I don't think that it good or necessary either so I consider it a defective idea by Ford.  Simple rules work best = "driver always has ultimate authority".
I should not have stated that it's "putting on the brake" - likely it's overriding the accelerator command from the pedal so it is just not allowing me to get any closer than the 4 bar setting.  (I use that mainly at night in sparse traffic on long trips so the situation is rare.  Like you I'm usually at 1 bar so there's not enough room for such a situation to occur anyway. )
Good idea - I'll pose the "gripe" in my signature line.
My 2019 ST behaves like yours.  Accelerate disables the cruise, lane mind, and adaptive, until I let off the gas and it resumes to the set speed and other settings.
Every cruise control I’ve ever had allows you to accelerate without cancelling cruise.  I think it’s a good feature.  No reason to disengage it if you’re trying to go faster.
  • Like 3
