Fuse question
Fredj72
On 10/15/2020 at 6:01 PM, Fredj72 said:
Good afternoon all. Looking for a little help on which fuse I need to use to run some switches to hook up some led underglow, led interor strips and led turn signals. I'm looking for my drl fuse but to no avail. Maybe I need to use my radio fuse? Please please help lol
Daylight running lamps are powered through the SJB. Same fuse as headlamps.
As for the add-on exterior lighting, you could tie into several different circuits. For example, consider using one of the power point circuits (they are hardly used anyway) and provide a separate, online fuse to protect the circuit against road hazards.
Fuse at 150% of the anticipated load.
""Use SAE rated wiring in ALL automotive accessory wiring as the cheaper stuff is a fire hazard.""
