edgeidiot Posted October 22 Report Share Posted October 22 There are thousands of listings for S154D Rear-End Differentials on ebay. Most are remanufactured in China. Quote Link to comment Share on other sites More sharing options...
jhill40141 Posted October 22 Report Share Posted October 22 10 hours ago, edgeidiot said: There are thousands of listings for S154D Rear-End Differentials on ebay. Most are remanufactured in China. Those cheap ones made in China aren't and when u call ebay to buy one they tell you not to buy it Quote Link to comment Share on other sites More sharing options...
KCWISME Posted October 24 Report Share Posted October 24 I’m back on this old thread from February 23 after replacing that brand new RDU and change an oil every 15,000 miles I changed it this week again all kinds of metal shavings and noises coming from it contacted the dealer since buying new and only having 45,000 miles put on it, they said sorry Only one year warranty so now I’m back deciding to buy another one from China. Definitely not buying a new from Ford Sterling axle garbage or to try to totally delete or bypass the rear RDU if anybody reads this has anybody bypassed this by removing the dry shaft and the axles to the tires Quote Link to comment Share on other sites More sharing options...
jspec Posted October 24 Report Share Posted October 24 I am with you 100%. I bought a brand new S150 from the ebay seller I suggested. 1 year later I get a bad shudder from the rear. I replaced the rear axles and checked the driveshaft which all look perfect. Dealer said it was differential bushings. I replaced those. No good. I unplug the rear diff and it is gone. So no shavings or anything in the oil but I would guess the clutch is gone. Hitting OK on the dash to clear the error is easier then fixing this POS RDU. Quote Link to comment Share on other sites More sharing options...
KCWISME Posted 14 hours ago Report Share Posted 14 hours ago I did pull the drive shaft and the axle shafts on the RDU, left the RDU unit installed, electrical connection connected, everything seems to be working just fine, no warning lights on the dash, I basically have a front wheel drive now. Hope the PTU stays good I change fluid every 15,000. I hated to do it but since ford is building junk these days and not backing their product i guess i had no choice, after buying a brand new RDU from ford and it goes bad in one year and eight months, definitely not any different than the Chinese junk Quote Link to comment Share on other sites More sharing options...
