edgeidiot Posted October 22, 2025 Report Share Posted October 22, 2025 There are thousands of listings for S154D Rear-End Differentials on ebay. Most are remanufactured in China. Quote Link to comment Share on other sites More sharing options...
jhill40141 Posted October 22, 2025 Report Share Posted October 22, 2025 10 hours ago, edgeidiot said: There are thousands of listings for S154D Rear-End Differentials on ebay. Most are remanufactured in China. Those cheap ones made in China aren't and when u call ebay to buy one they tell you not to buy it Quote Link to comment Share on other sites More sharing options...
KCWISME Posted October 24, 2025 Report Share Posted October 24, 2025 I’m back on this old thread from February 23 after replacing that brand new RDU and change an oil every 15,000 miles I changed it this week again all kinds of metal shavings and noises coming from it contacted the dealer since buying new and only having 45,000 miles put on it, they said sorry Only one year warranty so now I’m back deciding to buy another one from China. Definitely not buying a new from Ford Sterling axle garbage or to try to totally delete or bypass the rear RDU if anybody reads this has anybody bypassed this by removing the dry shaft and the axles to the tires Quote Link to comment Share on other sites More sharing options...
jspec Posted October 24, 2025 Report Share Posted October 24, 2025 I am with you 100%. I bought a brand new S150 from the ebay seller I suggested. 1 year later I get a bad shudder from the rear. I replaced the rear axles and checked the driveshaft which all look perfect. Dealer said it was differential bushings. I replaced those. No good. I unplug the rear diff and it is gone. So no shavings or anything in the oil but I would guess the clutch is gone. Hitting OK on the dash to clear the error is easier then fixing this POS RDU. Quote Link to comment Share on other sites More sharing options...
KCWISME Posted November 1, 2025 Report Share Posted November 1, 2025 I did pull the drive shaft and the axle shafts on the RDU, left the RDU unit installed, electrical connection connected, everything seems to be working just fine, no warning lights on the dash, I basically have a front wheel drive now. Hope the PTU stays good I change fluid every 15,000. I hated to do it but since ford is building junk these days and not backing their product i guess i had no choice, after buying a brand new RDU from ford and it goes bad in one year and eight months, definitely not any different than the Chinese junk Quote Link to comment Share on other sites More sharing options...
honerboys Posted December 3, 2025 Report Share Posted December 3, 2025 (edited) these cars are not that hard to find in junkyards - maybe find one ..pull the RDU and dump the oil onto a black rag and look for metal - i found one with no metal in oil and it has been working well since install last november - way cheaper - and jspec ..did you keep your old RDU? - if so the clutch is very easy to swap - don't have to remove RDU...just discnnect driveshaft and 4 bolts on clutch pack - if you didn't keep it try the junkyard route - i think the clutches last longer than the gear portion Edited December 3, 2025 by honerboys Quote Link to comment Share on other sites More sharing options...
AnotherMrSmith Posted June 5 Report Share Posted June 5 On 6/18/2024 at 7:41 PM, Junior Morgan said: I have a 2016 ford edge 3.5L engine RDU was bad, bought a new one from ebay China version, however after driving about 1000 miles the new one goes bad am trying to find out if a 2.0, 2.7 or a 3.0 differential is compatible with the 3.5, could that be the problem why it went bad. Can someone explain, do I have to buy the 3.5, how does it work and no I didn't change it myself. Also looking at those eBay replacements. My daughter’s 2014 edge limited had the rear differential check out early. It only has 68,xxx miles AWD and never been in water. Did you program the pcm with forscan after you installed it and do the awd cycle? Wondering if those china ebay rdus are worth even looking at. Thanks in advance Quote Link to comment Share on other sites More sharing options...
DAM7700 Posted October 10 Report Share Posted October 10 I have a 2014 Edge Sport AWD 3.7 with 130k miles and just had the RDU's ATC replaced by a local stealership a couple months back after hearing sudden bad popping from the rear end when rolling. They said the ATC was bad and installed a new unit but never reported back on the condition of the RDU or the fluid condition even though I had replaced the fluid approx. 30k earlier. Now I hear mild whining from the rear end when driving after replacing the fluid again recently, and found some minor metal on the drain plug in the process. Now I think we need to look into replacing the whole RDU, and everywhere I look I can't seem to find a new replacement or a reasonable remanufactured one. Does anyone have an idea where I can find a new unit to replace this one with, or a quality rebuilt one?.....I really don't want to go with any bone-yard replacement as I don't want to go through all the work to replace it with someone else's lack of maintenance. 1 Quote Link to comment Share on other sites More sharing options...
