How to lock fob in vehicle?
First - I did a search here and could not find anything.
A lot f the videos I watched touted the idea of locking the fob in the vehicle if you didn't want to carry it with you (say when at the beach or whatever) and using the door pad to unlock the vehicle.  Well, I tried to do this and the Edge won't lock with the fob inside the vehicle.  I also wondered if you do lock the fob in the vehicle, does the touch-sensitive unlocks still work, or are they disabled?
How is this accomplished, or is it even able to do this?
Thanks.
My 2017 Sport will lock with the fobs inside, and I assume its the same for all the others.
Leave the fobs inside, close the door and touch the top of the door handle and it will lock, or hold two numbers simultaneously on the keypad, then unlock with the keypad.
If locked with the fobs inside, the only way to open it is with the keypad or with the key that you can detach from the FOB (prior to them being locked in the vehicle).
Edited by 1004ron
