Alternator - Check Charging System
So I got a message on the dash to check charging system. It's a 2014 Sport with 100,000 miles. The battery is a 3 year old Motorcraft that tests fine so I figure maybe it's the alternator. Not out of the question given age and mileage. But when I run a voltmeter test while running I get 13.7 volts. Would this be low enough to warrant the dash warning? I know ideally it should be 14 or higher. Anyone with any experience on this? I plan on taking to get looked at next week and will probably just end up replacing the alternator and belt for piece of mind.
Check the battery cable connectors for corrosion.
Test the battery running a LOAD test (test the actual CCAs).
Check for DCTs. (Anything that turns on the IC warning will set a code).
The voltage being output to the alternator can be controlled by the PCM. Codes will tell you if either of these are involved.
