TGH Posted July 24, 2021 Report Share Posted July 24, 2021 The headlights on my 2017 EDGE are aimed very low on the low and high beams. I’ve adjusted the headlights as high as they will go but they still shine low in front of the vehicle when driving. On high beams, they are so low it doesn’t bother oncoming traffic or anyone I’m follow. any thoughts on how to raise the aim of the lights? The Ford dealership says ithat’s normal due to the design of the Edge. Thoughts? Or ideas? I don’t see others complaining of this issue Quote Link to comment Share on other sites More sharing options...
ben senise Posted July 24, 2021 Report Share Posted July 24, 2021 (edited) the dealer is just fobbing you off. "normal" because they don't want to deal with it. the first thing i would suggest is to measure the aim.if you are within spec, then that's as good as it will get. if not, then there's another problem. check this out: https://owner.ford.com/support/how-tos/exterior/lights/how-to-adjust-headlights.html# on a related subject, the headlights on my 2016 Ti were so terrible that they were dangerous and were the absolute #1 reason why i got rid of the car and bought a new edge with the much improved LED headlights. the engineering of the standard lights in that model, and i suppose it's the same as yours, is terrible. they are weak and poorly focused. i live in an area with a ton of wildlife and it is terrifying to drive here at night. there are many many threads in this forum that discuss how to improve the lights. be sure to check those out. i hacked some different sized bulbs to be able to use them in my headlights. they were a little bit brighter but not much. some people use LED or HID bulbs. but in the end, the reflectors and lenses just suck. Edited July 25, 2021 by ben senise missing word Quote Link to comment Share on other sites More sharing options...
TGH Posted July 26, 2021 Author Report Share Posted July 26, 2021 Thanks Ben, I had already replaced the low and high beams with LED’s which helps with brightness but not with aiming the lights higher. I’ll need to park the Edge in front of a wall and measure the center height to see if it’s where it should be. Quote Link to comment Share on other sites More sharing options...
akirby Posted July 26, 2021 Report Share Posted July 26, 2021 10 hours ago, TGH said: Thanks Ben, I had already replaced the low and high beams with LED’s which helps with brightness but not with aiming the lights higher. I’ll need to park the Edge in front of a wall and measure the center height to see if it’s where it should be. Well you didn’t mention that you replaced the bulbs with LEDs. I bet the bulbs are installed wrong or just don’t work with the edge housing. Put OEM bulbs in and see if it goes back to normal. 1 Quote Link to comment Share on other sites More sharing options...
Dave F Posted November 25, 2025 Report Share Posted November 25, 2025 I replaced my low beam bulbs with LEDs. They are brighter but still only shine on about 30 feet of the road in front. Can they be adjusted separately from the high beams? 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted November 26, 2025 Report Share Posted November 26, 2025 On 11/24/2025 at 11:56 PM, Dave F said: I replaced my low beam bulbs with LEDs. They are brighter but still only shine on about 30 feet of the road in front. Can they be adjusted separately from the high beams? Pity the oncoming drivers that will be blinded using LED's in the low beams. 1 Quote Link to comment Share on other sites More sharing options...
