Code po301
07Bluesilver
I'm getting a codepo301 on the Edge. I replaced Spark plug, o rings on injectors that was destroyed previous owner must had someone work on it and didn't do so a good job. Moved coil to cylinder 4. but still getting it on cylinder 1. Should I change the fuel injector next? Intake manifold and intake have no leaks, maf flow is good. I hope it's not the pcm! Any info would be appreciated. THANKS! Sorry if placed in wrong section it can be moved if need to.
Edited by 07Bluesilver
