Ford Edge driver door will not open when the key fob is near it.
I have a 2016 Ford Edge "SPORT" with a moonroof. I bought it used two weeks ago from Carvana. I discover that I can open the key fob near my passenger door without any issue when I have the key fob. But that is the case for the driver-side door (its stays lock). The only way to open the driver side is using the keypad or click the open button on the key fob. I do think the driver-side door is malfunctioning. Is this an easy fix, or do I need to take it to a Ford dealer? Thank you in advance for your answer to my question. Be safe and be well, everyone!
So the driver door's intelligent access unlock function does not work, what about for locking the doors? I don't recall this issue being brought up before. What if you try the rear driver side door, does it then open all doors? The rear doors on the Edge also have intelligent access.
If the rear door does open all door locks, my guess is that there might be a fault in the driver door handle or the connection to it.
