LUPID Posted October 18, 2021 Report Share Posted October 18, 2021 Hi, My 2013 Sport keeps having power steering issues. Specifically, the hose erupts where the o-ring meets the pump. It happens only on hard left turns, like in a parking lot or making a u turn. This has happened 3x now. The mechanic keeps replacing the o-ring, but since it keeps happening it feels like the problem is either in the pump, where it connects TO the o ring or the relief valves in the steering system are stuck closed (I don't know the exact term). Is this a know issue and is there a known fix? Thanks, L Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 19, 2021 Report Share Posted October 19, 2021 how many miles on your Edge? there is a banjo bolt kit ford issued but nothing else really for power steering. most issues center around a hose leak needing either brazing or replacement. if power steering has not been flushed regularly, it will cause a number of issues, ending in the failure of the pump and/or rack. Quote Link to comment Share on other sites More sharing options...
LUPID Posted October 19, 2021 Author Report Share Posted October 19, 2021 It has just over 90k miles. Thanks for the info. The hose has been replaced 2x and the o-ring 2x too. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 19, 2021 Report Share Posted October 19, 2021 assuming ford/motorcraft parts were used. if fluid has never been flushed, you will want to do that as well, maybe more than a couple of times, until the fluid remains pink/red and new looking. i don't think you can actually monitor fluid pressure in the steering system, although there is a switch that sets off an alert for too high a pressure. Quote Link to comment Share on other sites More sharing options...
LUPID Posted October 22, 2021 Author Report Share Posted October 22, 2021 Thanks man. Mechanic still has it. Fingers crossed. Quote Link to comment Share on other sites More sharing options...
Jeremiah Rice Posted May 30, 2022 Report Share Posted May 30, 2022 On 10/21/2021 at 8:04 PM, LUPID said: Thanks man. Mechanic still has it. Fingers crossed. What did you end up learning as a cause of this issue? My 2012 has done this twice in the past week since replacing the pressure line three months ago. Quote Link to comment Share on other sites More sharing options...
