2007 Ford Edge hvac, actuator, heater core Desperate
hello
I am here again searching for answers.
A year ago I had to put into a full hvac (not sure of the name) vents... etc. that involved removing the dashboard and 3000 dollars.    Now the same thing is happening again.   one side of the car, passenger, toasty warm and the drivers side lukewarm.  They at the dealership said It was a faulty actuator which they replaced for 300.00.   We get the car back and head out to test it and absolutely nothing has changed.   It goes back the same day and the tech is sick so now 5 days later they are saying it Is a bad heater core and they need another 1000+ to fix that.
I bought the car from them 2 years to the day ago and the next day of owning the full hvac system "failed".  Now they are saying the above and that the coolant if filthy.  I put 4500 miles on that car in 2 years.
Please, anyone have some advice on what to do?    I think I shouldn't have to pay for the actuator... I also am surprised the coolant is filthy and what they say, the cause of the blockage in the core.   One side of the car is toasty and hot!  The other Lukewarm.    Is there 2 heater cores?
Thank you to anyone who wants to give me the time to help.
  • 1 year later...
One way to test the heater core is the run car to heat coolant, feel heater core  inlet and output hose. If outlet only is cold, (1) core is plugged OR (2) core has air pocket. If plugged it can sometimes be cleared by pressue flusing by reversing the flow (connect pressure hose to outlet and reverse flush core).
If car has EMTC (manual), the blend door module is connected to both doors on one shaft; and assume shaft is broken.
If car has DATC (automatic),  there are two blend door actuators and one is malfuncting. You can tell which actuator is failing by turning on heat. Cold side is failure. Causes of failure include broken interior gears, a burnt out motor or loss of output shaft gear position.
You can try a blend door reset procedure and see if it resets.
(1) remove fuse(s) for 60 seconds. Then start car, run a/c for a few minutes to allow HVAC to initialize and calibrate actuators. Takes about a minute. Switch car off and replace fuses. Start car again and wait 1/2 minute and verify mode door operation.
▪︎You can also try resetting the HVAC module.
Press the heater control button and the AC button simultaneously and hold for a few seconds. Release both and then push the heater button again to run diagnostics. (The vents will blow air in a cycle for about 20 seconds during this phase).
Read any codes shown on screen (top right or left corners). Press AUTO to reset to exit diagnostics.
If you need to replace an actuator, there have been descriptions posted in this forum by members on how to do it. Use the search feature.
Edited by enigma-2
  • 9 months later...
Hi, I’m wondering if you (or anyone from this forum) knows how to access the shaft that you referenced on a manual, single-zone Unit?  I believe this might be the issue on my 2008 Edge but don’t know how to verify or even access the shaft or doors. I can see the actuator moving but no change in temp. Trying to check this as a possible solution before replacing the heater core. Thank You!
No insights on the Blend Door(s) and operating shaft are provided in the Workshop Manual, unfortunately, though YouTube includes video of a Ford truck owner cutting a portion of its climate control housing to access a blend door needing repair, as an alternative to removing the entire housing from behind the dash.
@WWWPerfA_ZN0W's recent advice on performing an actuator reset is worth a try.
Document download links>
Heater Core And Evaporator Core Housing - Removal and Installation - 2008 Edge Workshop Manual.pdf
Heater Core - Removal and Installation - 2008 Edge Workshop Manual.pdf
Temperature Blend Door Actuator - RH, Dual-Zone EATC - Removal and Installation - 2008 Edge Workshop Manual.pdf
Good luck!
Edited by Haz
  • 1 year later...
On 2/22/2023 at 8:35 AM, Dfowlers4 said:
I am having the same problem with a 07. Replaced by dealer 6 months after purchase because of no heat to driver. Doing something again now.
Something isn't right.
Returning back to this post.    New heater core, new plenum, accuators work, I am guessing 2 things.    Air in the line or somehouw the heater core is clogged.     Driver side cold.
  • Confused 1
Thank you for this post.   Mechanics are telling me it is the heater core, it was replaced in 2019 and 3k to have a mechanic do it today.  I am going to try the burp and if that doesn't work would you shy away from a flush simply for the reason it could damage the core or would you do it in hopes of fixing the cold air on drivers side?
Flush won't harm a heater core unless its already compromised.
Most of these problems are caused by an actuator. (Note in some cases the actuator is working but the shaft that runs between the two doors was broken. Even though the car didn't have a separate heating system, the passenger side was working but the shaft running over to the other side was broken.) Yours may be ok, but I'd verify that the actual doors are opening and closing properly before spending $3k.
As the heater core was replaced in 2019, the only reason (that I'm aware of) that would cause a heater core to clog is by not changing coolant at 105k miles or by mixing different coolants without doing a complete flush. (I'm aware that the maintenance manual specifies 105k miles, but I change mine at 60k.)
Final question for you,    I have pulled the actuator on the drivers side and manually moved the blend door to heat.  The passenger side works and vents heat.   Could the passenger side cause cold air to the drivers side?  From the diagrams I have looked at I didn't think that was possible, also Is there a third actuator that I can't access without taking the entire dashboard apart?
It would be nice not to flush if it is simply the passenger side hogging all the heat.
If a 3rd accuator exist in the center pellum then I am stuck with a cost.
I hope I am not annoying and confusing you with my words on text.   I am greatly appreciative.
mike
You are awesome.
Thank you.
I have decided that the Core has to be partially clogged, both hoses leaving the core were hot.
I am going with a space heater that runs off the ash tray to keep the wifes feet warm :).
I like the motors and power plus the ride is good but now now I am leery about buying another Edge due to this heater core b.s.
keep up the great work,  I am following you.
Well, if it makes you feel any better, it's not just the Edge that has this issue.  I have seen some problems over on the Explorer forum, and I had to have the blend door/actuator issue repaird on my old F-250.  I have seen it on other year models as well.  So it seems to be more a Ford issue rather than a specific model.  I'm sure other brands have issues as well, but I can't be sure since I have had mostly Fords.  My Dodge Charger did not have this type of issue.  I have a 2016 Edge, with just over 100K, and no issue with that yet.  My Explorer is a 2023 with around 45K, and no issues with that one yet either.  Yours is a 2007, so things are going to go wrong with it.  It doesn't mean it's necessarily a bad car, it's just getting old.
There, now don't you feel a little better??
After re-reading previous, on the standard hvac setups, the heat/cold is controlled by an actuator on one side or the other (forget which) and has a plastic rod that extends over to the other side to control that side. I've seen a report where the rod broke. (I think it controlled the passenger sidevand the rod simultaneously  controlled the drivers side. Easiest way to check is to watch the heat/cool door on the drivers side and switch between heat & a/c. If the passenger door moves but the drivers doesn't, you found your problem. If both move, the core is partly clogged.
On the duel systems, each side is controlled separately with separate actuators. There is a history of these actuators failing in the Ford line.
Its possible that the core is clogged again. Rather uncommon however. Most common cause is by using different coolants. Mix the wrong types are they congel forming a thick goo, and block part of the heater core. Never read where a flush cleared it. Think it would be better to disconnect the heater hoses and do a power flush just on the heater core. I did this many years ago by connecting the harden hose to one side heater hose and opening the tap. (Back then, Prestone sold a kit, a tee, to tap into your heater hose with a garden hose threaded connection on the top of the tee. Designed to do a flush at each coolant change.) Anyway, it worked. (But I'm not advising. Heater cores are made cheaper today.)
Edited by enigma-2
