Ekim Posted February 8, 2022 Report Share Posted February 8, 2022 hello I am here again searching for answers. A year ago I had to put into a full hvac (not sure of the name) vents... etc. that involved removing the dashboard and 3000 dollars. Now the same thing is happening again. one side of the car, passenger, toasty warm and the drivers side lukewarm. They at the dealership said It was a faulty actuator which they replaced for 300.00. We get the car back and head out to test it and absolutely nothing has changed. It goes back the same day and the tech is sick so now 5 days later they are saying it Is a bad heater core and they need another 1000+ to fix that. I bought the car from them 2 years to the day ago and the next day of owning the full hvac system "failed". Now they are saying the above and that the coolant if filthy. I put 4500 miles on that car in 2 years. Please, anyone have some advice on what to do? I think I shouldn't have to pay for the actuator... I also am surprised the coolant is filthy and what they say, the cause of the blockage in the core. One side of the car is toasty and hot! The other Lukewarm. Is there 2 heater cores? Thank you to anyone who wants to give me the time to help. Quote Link to comment Share on other sites More sharing options...
Dfowlers4 Posted February 22, 2023 Report Share Posted February 22, 2023 I am having the same problem with a 07. Replaced by dealer 6 months after purchase because of no heat to driver. Doing something again now. Something isn't right. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 1, 2023 Report Share Posted March 1, 2023 (edited) One way to test the heater core is the run car to heat coolant, feel heater core inlet and output hose. If outlet only is cold, (1) core is plugged OR (2) core has air pocket. If plugged it can sometimes be cleared by pressue flusing by reversing the flow (connect pressure hose to outlet and reverse flush core). If car has EMTC (manual), the blend door module is connected to both doors on one shaft; and assume shaft is broken. If car has DATC (automatic), there are two blend door actuators and one is malfuncting. You can tell which actuator is failing by turning on heat. Cold side is failure. Causes of failure include broken interior gears, a burnt out motor or loss of output shaft gear position. You can try a blend door reset procedure and see if it resets. (1) remove fuse(s) for 60 seconds. Then start car, run a/c for a few minutes to allow HVAC to initialize and calibrate actuators. Takes about a minute. Switch car off and replace fuses. Start car again and wait 1/2 minute and verify mode door operation. ▪︎You can also try resetting the HVAC module. Press the heater control button and the AC button simultaneously and hold for a few seconds. Release both and then push the heater button again to run diagnostics. (The vents will blow air in a cycle for about 20 seconds during this phase). Read any codes shown on screen (top right or left corners). Press AUTO to reset to exit diagnostics. If you need to replace an actuator, there have been descriptions posted in this forum by members on how to do it. Use the search feature. Edited March 1, 2023 by enigma-2 Quote Link to comment Share on other sites More sharing options...
kecusc Posted December 6, 2023 Report Share Posted December 6, 2023 On 2/28/2023 at 8:43 PM, enigma-2 said: If car has EMTC (manual), the blend door module is connected to both doors on one shaft; and assume shaft is broken. Hi, I’m wondering if you (or anyone from this forum) knows how to access the shaft that you referenced on a manual, single-zone Unit? I believe this might be the issue on my 2008 Edge but don’t know how to verify or even access the shaft or doors. I can see the actuator moving but no change in temp. Trying to check this as a possible solution before replacing the heater core. Thank You! Quote Link to comment Share on other sites More sharing options...
Haz Posted December 7, 2023 Report Share Posted December 7, 2023 Welcome to the Forum, kecusc ! Document download links> Control Components - Climate Control Systems - Description and Operation - 2008 Edge Workshop Manual.pdf Climate Control - Temperature Blend Door Actuator — LH - Removal and Installation - 2008 Edge Workshop Manual.pdf Temperature Blend Door Actuator — LH - Enhanced Image #1 - 2008 Edge Workshop Manual.pdf Temperature Blend Door Actuator — LH - Enhanced Image #2 - 2008 Edge Workshop Manual.pdf Good luck! 1 Quote Link to comment Share on other sites More sharing options...
kecusc Posted December 8, 2023 Report Share Posted December 8, 2023 Thanks @Haz! Do you know if there is a way to access the actual blend door and not just the actuator? I’m wondering if in my case the door itself is the problem and not the actuator. Quote Link to comment Share on other sites More sharing options...
Haz Posted December 10, 2023 Report Share Posted December 10, 2023 (edited) No insights on the Blend Door(s) and operating shaft are provided in the Workshop Manual, unfortunately, though YouTube includes video of a Ford truck owner cutting a portion of its climate control housing to access a blend door needing repair, as an alternative to removing the entire housing from behind the dash. @WWWPerfA_ZN0W's recent advice on performing an actuator reset is worth a try. Document download links> Heater Core And Evaporator Core Housing - Removal and Installation - 2008 Edge Workshop Manual.pdf Heater Core - Removal and Installation - 2008 Edge Workshop Manual.pdf Temperature Blend Door Actuator - RH, Dual-Zone EATC - Removal and Installation - 2008 Edge Workshop Manual.pdf Good luck! Edited December 10, 2023 by Haz 1 Quote Link to comment Share on other sites More sharing options...
Ekim Posted November 19 Author Report Share Posted November 19 On 2/22/2023 at 8:35 AM, Dfowlers4 said: I am having the same problem with a 07. Replaced by dealer 6 months after purchase because of no heat to driver. Doing something again now. Something isn't right. Returning back to this post. New heater core, new plenum, accuators work, I am guessing 2 things. Air in the line or somehouw the heater core is clogged. Driver side cold. 1 Quote Link to comment Share on other sites More sharing options...
Ekim Posted Wednesday at 02:50 PM Author Report Share Posted Wednesday at 02:50 PM On 2/28/2023 at 9:43 PM, enigma-2 said: One way to test the heater core is the run car to heat coolant, feel heater core inlet and output hose. If outlet only is cold, (1) core is plugged OR (2) core has air pocket. If plugged it can sometimes be cleared by pressue flusing by reversing the flow (connect pressure hose to outlet and reverse flush core). If car has EMTC (manual), the blend door module is connected to both doors on one shaft; and assume shaft is broken. If car has DATC (automatic), there are two blend door actuators and one is malfuncting. You can tell which actuator is failing by turning on heat. Cold side is failure. Causes of failure include broken interior gears, a burnt out motor or loss of output shaft gear position. You can try a blend door reset procedure and see if it resets. (1) remove fuse(s) for 60 seconds. Then start car, run a/c for a few minutes to allow HVAC to initialize and calibrate actuators. Takes about a minute. Switch car off and replace fuses. Start car again and wait 1/2 minute and verify mode door operation. ▪︎You can also try resetting the HVAC module. Press the heater control button and the AC button simultaneously and hold for a few seconds. Release both and then push the heater button again to run diagnostics. (The vents will blow air in a cycle for about 20 seconds during this phase). Read any codes shown on screen (top right or left corners). Press AUTO to reset to exit diagnostics. If you need to replace an actuator, there have been descriptions posted in this forum by members on how to do it. Use the search feature. Thank you for this post. Mechanics are telling me it is the heater core, it was replaced in 2019 and 3k to have a mechanic do it today. I am going to try the burp and if that doesn't work would you shy away from a flush simply for the reason it could damage the core or would you do it in hopes of fixing the cold air on drivers side? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted Wednesday at 08:49 PM Report Share Posted Wednesday at 08:49 PM Flush won't harm a heater core unless its already compromised. Most of these problems are caused by an actuator. (Note in some cases the actuator is working but the shaft that runs between the two doors was broken. Even though the car didn't have a separate heating system, the passenger side was working but the shaft running over to the other side was broken.) Yours may be ok, but I'd verify that the actual doors are opening and closing properly before spending $3k. As the heater core was replaced in 2019, the only reason (that I'm aware of) that would cause a heater core to clog is by not changing coolant at 105k miles or by mixing different coolants without doing a complete flush. (I'm aware that the maintenance manual specifies 105k miles, but I change mine at 60k.) 1 Quote Link to comment Share on other sites More sharing options...
Ekim Posted Saturday at 03:21 PM Author Report Share Posted Saturday at 03:21 PM Final question for you, I have pulled the actuator on the drivers side and manually moved the blend door to heat. The passenger side works and vents heat. Could the passenger side cause cold air to the drivers side? From the diagrams I have looked at I didn't think that was possible, also Is there a third actuator that I can't access without taking the entire dashboard apart? It would be nice not to flush if it is simply the passenger side hogging all the heat. If a 3rd accuator exist in the center pellum then I am stuck with a cost. I hope I am not annoying and confusing you with my words on text. I am greatly appreciative. mike Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted Saturday at 08:23 PM Report Share Posted Saturday at 08:23 PM (edited) At this point I'd say you ruled out all other possibilities. I'll attach a copy of a Ford cooling system corrosion service bulletin. You may find it useful as to what additional parts to replace when doing a flush, etc. . 2009 MKX Cooling System Corrosion.pdf Edited Saturday at 08:24 PM by enigma-2 Quote Link to comment Share on other sites More sharing options...
Ekim Posted Sunday at 08:58 PM Author Report Share Posted Sunday at 08:58 PM You are awesome. Thank you. I have decided that the Core has to be partially clogged, both hoses leaving the core were hot. I am going with a space heater that runs off the ash tray to keep the wifes feet warm :). I like the motors and power plus the ride is good but now now I am leery about buying another Edge due to this heater core b.s. keep up the great work, I am following you. Quote Link to comment Share on other sites More sharing options...
edjunior Posted 20 hours ago Report Share Posted 20 hours ago Well, if it makes you feel any better, it's not just the Edge that has this issue. I have seen some problems over on the Explorer forum, and I had to have the blend door/actuator issue repaird on my old F-250. I have seen it on other year models as well. So it seems to be more a Ford issue rather than a specific model. I'm sure other brands have issues as well, but I can't be sure since I have had mostly Fords. My Dodge Charger did not have this type of issue. I have a 2016 Edge, with just over 100K, and no issue with that yet. My Explorer is a 2023 with around 45K, and no issues with that one yet either. Yours is a 2007, so things are going to go wrong with it. It doesn't mean it's necessarily a bad car, it's just getting old. There, now don't you feel a little better?? Quote Link to comment Share on other sites More sharing options...
