Silly question time
Chris71Mach1
So my 2010 3.5L has fallen victim to the age-old issue of the water pump seals failing and leaking coolant into the engine.  Yippee, my motor is toast.  I'm looking for a re-manufactured engine (I just don't trust the ticking time bomb that would be a junk yard donor engine), and I find that everybody has options of either with or without the engine oil cooler.  How do I check and tell if my 2010 has that cooler so I can make sure to choose the right engine to swap into this thing?
If your edge came from factory with the tow package it will have the oil cooler. and yeah the adapter + extra tubing is hard to miss.
https://parts.levittownfordparts.com/v-2010-ford-edge--sel--3-5l-v6-gas/cooling-system--oil-cooler
if you dont have the cooler you can still buy an engine with the cooler and simply discard those fittings.
