1004ron Posted January 29 Author Report Share Posted January 29 Looks like USPS is on a go slow strike in my area - takes about a week to get past my local distribution center which up until now was one day, max two days. Installed last night and its back to normal operation. The butchered plastic covers also have some odd grey bonding which must have been done by SafeLite. Unlike some of the YT videos I've seen, the gel actually covers the lens, and the gel on the old one was covered in dust/debris. 3 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 29 Report Share Posted January 29 Thanks for all of the photos. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 22 Report Share Posted February 22 (edited) With inspiration from @1004ron replacing their rain sensor, I will attempt to install a rain sensor into my Edge. I always find myself constantly adjusting the wiper speed every time it rains or snows, and it gets annoying if I shut the vehicle off and the wiper’s don’t return to their resting position because they are in the middle of wiping the windshield. I will have to try to sand the black stuff off of the windshield so the sensor can be installed. Edited February 22 by Wubster100 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 22 Report Share Posted February 22 @HazCan you please post the rain sensor wiring diagrams? Quote Link to comment Share on other sites More sharing options...
Haz Posted February 23 Report Share Posted February 23 @Wubster100: Requested information is attached below as PDF documents... Good luck! Rain Sensor Module - Connector C914 Pinout - 2021 Edge.pdf Rain Sensor Module - Connector C914 Location - 2021 Edge.pdf Rain Sensor Module - Power Distribution Wiring Diagram - 2021 Edge.pdf Rain Sensor Module - Grounds Wiring Diagram - 2021 Edge.pdf Rain Sensor Module with Adaptive Cruise - Wiring Diagram - 2021 Edge.pdf IMAGE PROCESSING MODULE A (IPMA) - Connector C9224 Pinout - 2021 Edge.pdf Rain Sensor Module - Wiring Diagram - 2021 Edge.pdf Wipers and Washers - Rain Sensor Wiring Diagram 81-2 Extension - 2021 Edge.pdf Wipers and Washers - Rain Sensor Wiring Diagram 81-1 Extension - 2021 Edge.pdf 1 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted May 2 Author Report Share Posted May 2 @Haz I put your instructions on the trim piece at the top of the windshield to good use today. I went through the car wash and the high pressure jets directed at the roof caused a major noise so I knew something has come adrift - pull over and the trim piece was holding on by just the far right side. I re-attached the far left white clip and drove home. At home I started removing it and found that it was only one spot of SikaFlex holding it from coming off. All the other spots of SikaFlex were not high enough to make contact with the trim piece and the body. I should received the tube of SikaFlex on Saturday and will check with my local Ford dealership if they have the white clips in stock, or it will be a wait for that. Not bike weather so I forced to use the car without that trim piece. This was obviously a bad installation from the assembly and the SafeLite just disturbed it during the install of the third windshield. 2 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted Saturday at 06:08 PM Author Report Share Posted Saturday at 06:08 PM Job done. After a closer look I could tell that this was a botched installation by SafeLite when they installed the 3rd windshield. I placed painters tape over the areas above the 7 white plastic clips and started at the far left thumping the tape and hearing the clips engage. I'm confident that its secure now. 2 1 Quote Link to comment Share on other sites More sharing options...
