pjtaxi Posted March 20 Report Share Posted March 20 How hard is it to remove hood on Edge? Got a 3 inch dent on leading edge of hood and think I can pop it out if I get hood off Thanks for any info Quote Link to comment Share on other sites More sharing options...
Haz Posted March 20 Report Share Posted March 20 Welcome to the Forum, @pjtaxi ! From the 2020 Edge Workshop Manual... Hood - Removal and Installation - 2020 Edge Workshop Manual.pdf Hood Alignment - General Procedures - 2020 Edge Workshop Manual.pdf Hood Latch - Removal and Installation - 2020 Edge Workshop Manual.pdf Active Grille Shutter - Removal and Installation - 2020 Edge Workshop Manual.pdf Front Bumper Cover - Removal and Installation - 2020 Edge Workshop Manual.pdf Good luck! 4 Quote Link to comment Share on other sites More sharing options...
Tim W. AZ Posted March 20 Report Share Posted March 20 If you have to lower or remove the adjustable rubber stops, put a small spot of grease on the tops to determine the proper height. Start low and adjust higher and when it leaves a small amount of grease on the underside of the hood, you're good. 1 Quote Link to comment Share on other sites More sharing options...
kruzr1 Posted March 21 Report Share Posted March 21 You could also use a piece of paper placed between the 2 contact areas. Adjust the stoppers until you have resistance when pulling the paper with the hood closed. I believe this method was also in a Ford SSM. 2 Quote Link to comment Share on other sites More sharing options...
Haz Posted March 21 Report Share Posted March 21 Link to Special Service Message 49931 - 2015-2021 Edge, 2016-2018 MKX, 2019-2021 Nautilus - Hood Bounce Or Flutter At High Speeds Good luck! Quote Link to comment Share on other sites More sharing options...
