Shimmy, shake, jiggle, when >50 mph and accelarating - RESOLVED
1004ron
My 2017 Sport is very well maintained with 107K miles on the clock.
It runs very smooth but has a slight drive-line gear whine when above 50 mph and still sending power to the rear, but I can live with that.
More concerning is when on the interstate cruising at speeds above +- 50 mph and accelerate fairly hard, I can feel a shimmy shake which feels like an out of balance wheel, but subsides as soon as I let off the accelerator.
Next weekend I'll be doing a lube service including the PTU, and wanted to hear from you folks what I should inspect to identify the cause of the shimmy shake.
I'll also get the wheels balanced, but doubting that this is what I'm feeling.
My wife's BMW X5 has two of these hydraulic engine mounts, and I have replaced one of them - it leaked oil and was compressed.
The Edge Sport has only one of them on the right side and mine looks compressed/collapsed - see below photo - hows this compare to yours?
If I get off work early enough tomorrow I'll get it up on four jack stands and inspect everything underneath - I always inspect the drive-shaft rubber boots when I do oil changes and they're all in good condition with no lubricant leakage.
@1004ron
I looked at mine and it looks like yours. I cannot determine if it's compressed or not. The rubber "flap" circled in the screenshot below is not compressed and can be moved. It seems like it is there to prevent metal to metal contact on high engine movements or vibrations.
Also there is no oil leaking and no vibrations.  I only have a clunk during throttle tip in after coasting, but I don't think it is from the mounts.
Thanks omar302
That rubber flap on mine is also not compressed, and no oil leaks to be seen - I'm guessing the mount is still good.
Today I got it on four jack stands and checked everything out on the underside, drive shafts, all engine and transmission mounts, prop-shaft as best I could see and feel.
I did an engine oil change and PTU change while I had it elevated - only been 3K miles since I last changed both.
First pulled the PTU fill plug and nothing dripped - was concerned that trans fluid was leaking by the seals, but that's a non-issue now.
The only thing done different was I rotated the wheels - all four tire wear is even, fronts same wear as rears.
I then took it on the interstate and could not invoke the shimmy again, so I'm suspecting one of the wheels that was on the front needs balancing - will be going back to Discount Tires for all four balancing.
I haven't done any further research on the gear whine.
Just last week I changed the PTU fluid and the magnetic plug was clear and the oil looked good.
Sometimes the AWD keeps power to the rear at speeds greater than +- 50 mph and that's when its more prominent.
I back off the throttle and when the power goes to the front wheels only it seems quieter.
Got the wheels balanced at Discount Tires, and as expected they tried hard to use the opportunity to sell me a set of new tires - I declined and went with the free balancing.
They reported minor balance weight changes.
Haven't had the shimmy shake, but if it happens again I'll do more searching.
  • 7 months later...
It seems to be just a little worse - at the onset I've tried a lower gear but no change - it can get pretty severe and directly proportional to the torque applied when in the speed range (55 to 65 mph).
If I'm steady at around 60 mph and accelerate the shake will start - can actually see the hood shake left to right.
After noticing the wear on the inboard edge of the two front tires (see below linked thread) I'm suspecting its tie rods, so this weekend I'll get my wife to assist in jostling the steering wheel while I try to asses which tie rod it is (inner, outer, left, right)
I will change both sides but if it's the outer I'll do both outers, unless I find a rubber boot was the root cause I'll rethink the need to do both sides.
Now, I'm leaning towards going with Motorcraft unless someone can recommend anything better.
In about 15K miles I'll be installing new tires and need this resolved by then.
Today I got it on four ramps and with the engine running had my wife shuffle the steering wheel while I felt every joint and connection and couldn't find a thing.
I got one of our GoPro cameras from work thinking that I'd mount it and record the shake but couldn't find a location to mount it.
I'm not keen to start throwing parts at it so I'll wait until I get a set of new tires and then take it for alignment, which should be in about 5 to 10K miles (2 to 3 months).
Last year I was experiencing a vibration in the steering wheel. The shop I've been going to put it on a lift and put it in gear. As we looked from the rear of the vehicle there was at least one tire that was not running true. You could see the tread moving left and right and it wasn't the wheel. Those were Pirelli  tires, I now have continental tires on and problem solved.
  • 4 months later...
From what you describe I'm guessing yours was evident at specific speeds - mine is only there at a specifc speed range (55 - 65 mph) AND accelerating - light throttle just cruising at any speed has zero vobration.
Tomorrow (11/1/25) around noon I'll have new tires on but don't expect any change to this issue.
On Saturday afternoon or Sunday I'll get in up on four jack-stands, and front wheels off, then scrutinize all potential areas such as the lower control arm buses - if its that I get the complete  lower control arms.
Should I stick with Motorcraft or are Moog and Mevotech acceptable?
https://www.rockauto.com/en/catalog/ford,2017,edge,2.7l+v6+turbocharged,3434543,suspension,control+arm,10401
This video describes what I'm experiencing.
Quote
You feel a shaking or vibration while you drive, but not during quick movements like quick acceleration or turning. This vibration comes through the floor or seat while you gently accelerate.
Recently occasionally when I back out my garage then turn the wheel full lock to the right to move down my driveway I've heard and felt a soft knock on the left front.
I have all my wrenching life avoiding the use of the "Parts Cannon", but that's about to change.
I suspected the left lower control arm bushes or ball joint so a couple of days ago I took a closer look at them, also used a pry bar to see if I could invoke some movement, but none - the inspection method used is flawed in that the control arm is in a taught position with the suspension fully extended.
I've ordered a new Fomoco control arm for $213 delivered, that might arrive in time for installation this weekend or it'll be the next weekend.
New control arm was delivered this afternoon and its installed.
Examining the old control arm bushes and ball-joint I'd say its in perfect serviceable condition.
The job is a real challenge and my advice is don't tackle this on your own in your garage - at least have a friend work with you and better still have a shop lift.
The bolts were SUPER tight - had to use a makeshift extension to my long breaker bar.
It is really difficult to get the bushes engaged and the ball joint. The drive shaft popped out and spilt a little more than half a quart - I just let it dribble into an oil pan while I manipulated the control arm into place.
Tomorrow I'll take it for a drive to get the tans temps up and then top up the fluid - not expecting any change to the shimmy shake, but if it has resolved it I'll be very happy.
Now I'm thinking possibly the strut bearing?
On 11/14/2025 at 10:29 PM, 1004ron said:
This video is exactly what I'm encountering - CV axle should be delivered next week and I'll install it on the weekend.
Can you check if the driver's side CV axle has any in/out play? Mine does have, especially if trying to move it from the inner CV case. Kind of like and as if the grease is this and the snap ring that holds the shaft in the transmission has play in it. Should have made a video of it.
The passenger front CV is tight with no play, so are both rear shafts. It is only the front Left (driver's) side.
I have had a clunking noise for a few years now that comes when I press on the accelerator pedal from coasting, which usually is an indication of a trans and/or engine mount, but even after changing all 5 mounts the clunking is still there.
This video is for an Explorer, but gives an idea of the play:
@omar302
I haven't compared the in-out play between the driver's vs passenger side.
The installed and the new driver's side does have some in-out play on the inboard joint which I accepted as normal.
I'll be installing the new CV Axle this evening or tomorrow and will clean, examine and report on what I find with the inboard joint.
Here's another report that makes me fairly confident that the CV Axle is my long ongoing issue.
Car Vibration When Accelerating: Suspect Your CV Joint - HubPages
Edited by 1004ron
New CV Axle installed and a trip on the interstate confirms that was the issue all this time.
Much easier job than the control arm replacement and with that said I might just go ahead and replace the right side.
The old inner joint felt just a little rough and the reason can be seen in the photos - also the lube appeared to be gear oil, not a grease, or maybe it was grease when it started out.
Today I installed the RH CV Axle.
The only battle I had was extracting the axle - all YT videos show smacking the inner joint with a hammer - I even went to Lowes to get a heavier hammer, and that didn't work - see the section of all-thread and nut in the photos - I cut a length of all-thread to fit snugly between the inner joint and a bolt head on the PTU, then holding it with a pliers I backed the nut out and as it reached the end of its thread the axle was free to extract - way better than beating on it.
The I noticed the friction material had come off the outboard brake pad - went to Autozone and got a set of new pads - found the same thing on the LH.
The LH CV Axle cured the vibration but I could still just a little at exactly 60mph with acceleration - that is gone now.
The inner joint on the RH axle had similar wear divots, just not as deep - the lubricant didn't run out like oil as was the case with the LH, but it looked an odd brown color.
  • 1004ron changed the title to Shimmy, shake, jiggle, when >50 mph and accelarating - RESOLVED
