johnmarkp Posted May 3 Report Share Posted May 3 The Lincoln mirrors are attached to the sheet metal not the small triangle by the glass. The sheet metal profile would have to be close. Not to mention the replacement part for the plastic Edge mount. Too bad, it would have made things pretty easy., 2 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted May 4 Author Report Share Posted May 4 Right on, @johnmarkp! The Edge mirrors attach differently. Here are the Edge CN mirrors: 1 Quote Link to comment Share on other sites More sharing options...
TXFRDOwner Posted May 22 Report Share Posted May 22 On 5/4/2025 at 5:04 AM, Wubster100 said: Right on, @johnmarkp! The Edge mirrors attach differently. Here are the Edge CN mirrors: I'm interested, did you find a vendor ? 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted May 22 Author Report Share Posted May 22 Not really, they are difficult and expensive. Quote Link to comment Share on other sites More sharing options...
TXFRDOwner Posted May 23 Report Share Posted May 23 12 hours ago, Wubster100 said: Not really, they are difficult and expensive. I might have a lead on a pair under $900.00 shipped from China ... More to follow. 1 1 Quote Link to comment Share on other sites More sharing options...
TXFRDOwner Posted May 26 Report Share Posted May 26 Seller's Name: Ohi Chen https://www.facebook.com/groups/1915936068714343/user/100010346019408/ 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted May 26 Report Share Posted May 26 Hmmm, maybe it's just me... Good luck! 1 Quote Link to comment Share on other sites More sharing options...
TXFRDOwner Posted May 26 Report Share Posted May 26 7 minutes ago, Haz said: Hmmm, maybe it's just me... Good luck! Oh I guess you can't see it if you're not a member of the Group. My Bad !!! You can message him directly: https://www.facebook.com/ohichen/ 1 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted May 26 Report Share Posted May 26 I wonder if you could make these with some 3D printing and creative cutting. I am pretty sure there is a enough room in the mirror case for the camera. 1 Quote Link to comment Share on other sites More sharing options...
TXFRDOwner Posted May 26 Report Share Posted May 26 (edited) On 5/26/2025 at 8:55 PM, johnmarkp said: I wonder if you could make these with some 3D printing and creative cutting. I am pretty sure there is a enough room in the mirror case for the camera. Hell yeah, I don't see why not, If one has the skill set for that. But it's worth mentioning that the Chinese Edge mirrors (premium trim) offer camera & power fold options. Pretty Sweet ! You would need to do a little bit of wiring modification, swap out your current window switch for P/N: GT4Z-14529-AA and do some DDM Forscan code change to make the power fold option work. Edited May 31 by TXFRDOwner 2 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted June 8 Author Report Share Posted June 8 The Chinese Edge has its IPMB located under the driver's seat area. Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted June 11 Author Report Share Posted June 11 @Haz can you post the connector pin out diagrams from the 2018 Ford Edge China of the door modules and right and left mirrors? Quote Link to comment Share on other sites More sharing options...
TXFRDOwner Posted June 12 Report Share Posted June 12 (edited) I plan on making a Y-Harness adapter from the 22pin Chinese Edge mirror connector split into a 16pin+4pin. The 16pin will plug into the edge mirror connector car side and the 4pin will be for the camera wiring. I included the connector housing (pdf) datasheets, you can purchase those from Mouser, Digikey or other online retailers. 19_Edge (China) Mirror Diagram.pdf C501B - (China) DDM.pdf C501A - (China) DDM.pdf C517 - (China) LH Mirror.pdf C615 - (China) RH Mirror.pdf C652A - (China) PDM.pdf C652B - (China) PDM.pdf 16Pin Male_CD_1419167.pdf 4Pin Female_1456983-1.pdf 4Pin Male_6-1419166-1.pdf 22Pin Female_2208021.pdf Edited June 12 by TXFRDOwner 2 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted June 12 Author Report Share Posted June 12 6 hours ago, TXFRDOwner said: I plan on making a Y-Harness adapter from the 22pin Chinese Edge mirror connector split into a 16pin+4pin. Good idea. I already have the connectors and pins for the IPMB. 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted June 12 Report Share Posted June 12 16 hours ago, Wubster100 said: @Haz can you post the connector pin out diagrams from the 2018 Ford Edge China of the door modules and right and left mirrors? 8 hours ago, TXFRDOwner said: I included the connector housing (pdf) datasheets, @Wubster100: Happy to see @TXFRDOwner satisfying your shared informational needs. Good luck! 2 Quote Link to comment Share on other sites More sharing options...
TXFRDOwner Posted June 12 Report Share Posted June 12 2 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted June 12 Author Report Share Posted June 12 Nice diagram 2 Quote Link to comment Share on other sites More sharing options...
dolsen Posted June 13 Report Share Posted June 13 17 hours ago, Wubster100 said: Nice diagram It would be great if this was a Ford/industry standard diagram. This would be SOOOOOOOO helpful instead of hoping you find the right thing based on description 😅 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted June 14 Author Report Share Posted June 14 So it looks like the Edge’s IPMB got moved from above the glove box to near the APIM area? It looks like the HVAC module is there instead of the IPMB. 1 Quote Link to comment Share on other sites More sharing options...
TXFRDOwner Posted June 14 Report Share Posted June 14 (edited) 31 minutes ago, Wubster100 said: So it looks like the Edge’s IPMB got moved from above the glove box to near the APIM area? It looks like the HVAC module is there instead of the IPMB. Correct, the IPMB is now under the driver seat. 2022 Edge - IPMB removal.pdf Edited June 14 by TXFRDOwner 2 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted July 8 Author Report Share Posted July 8 My mirrors have arrived! 3 Quote Link to comment Share on other sites More sharing options...
dolsen Posted July 9 Report Share Posted July 9 Oooooooooo shiny 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 13 Report Share Posted July 13 On 7/9/2025 at 7:58 AM, dolsen said: Oooooooooo shiny Yeaaaaa. Wonder how many Piglins he had to distract? 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted July 14 Author Report Share Posted July 14 (edited) 3 hours ago, enigma-2 said: Wonder how many Piglins he had to distract? The Piglins were easy. It just takes some gold. The real challenge was trusting a $530 shipment from a Chinese auto parts dealer. But it actually came through. Not a bad price considering that used mirrors go for about $200 each. Edited July 14 by Wubster100 1 Quote Link to comment Share on other sites More sharing options...
