Retrofit 360 Camera Into Ford Edge
The Lincoln mirrors are attached to the sheet metal not the small triangle by the glass.  The sheet metal profile would have to be close.  Not to mention the replacement part for the plastic Edge mount.  Too bad, it would have made things pretty easy.,
On 5/26/2025 at 8:55 PM, johnmarkp said:
I wonder if you could make these with some 3D printing and creative cutting.  I am pretty sure there is a enough room in the mirror case for the camera.
Hell yeah, I don't see why not, If one has the skill set for that. But it's worth mentioning that the Chinese Edge mirrors (premium trim) offer camera & power fold options. Pretty Sweet !
You would need to do a little bit of wiring modification, swap out your current window switch for P/N: GT4Z-14529-AA and do some DDM Forscan code change to make the power fold option work.
Edited by TXFRDOwner
I plan on making a Y-Harness adapter from the 22pin Chinese Edge mirror connector split into a 16pin+4pin. The 16pin will plug into the edge mirror connector car side and the 4pin will be for the camera wiring.
I included the connector housing (pdf) datasheets, you can purchase those from Mouser, Digikey or other online retailers.
19_Edge (China) Mirror Diagram.pdf C501B - (China) DDM.pdf C501A - (China) DDM.pdf C517 - (China) LH Mirror.pdf C615 - (China) RH Mirror.pdf C652A - (China) PDM.pdf C652B - (China) PDM.pdf 16Pin Male_CD_1419167.pdf 4Pin Female_1456983-1.pdf 4Pin Male_6-1419166-1.pdf 22Pin Female_2208021.pdf
  • Thanks 2
16 hours ago, Wubster100 said:
@Haz can you post the connector pin out diagrams from the 2018 Ford Edge China of the door modules and right and left mirrors?
@Wubster100: Happy to see @TXFRDOwner satisfying your shared informational needs.
Good luck!
17 hours ago, Wubster100 said:
Nice diagram
It would be great if this was a Ford/industry standard diagram. This would be SOOOOOOOO helpful instead of hoping you find the right thing based on description 😅
  • 4 weeks later...
Posted (edited)
3 hours ago, enigma-2 said:
Wonder how many Piglins he had to distract?
The Piglins were easy. It just takes some gold. The real challenge was trusting a $530 shipment from a Chinese auto parts dealer. But it actually came through. Not a bad price considering that used mirrors go for about $200 each.
Edited by Wubster100
Hard Lesson learned, GT4Z-14529-AA is a 4-pin window switch similar to the Fusion's. Not what we're looking for.
Instead I'm now looking at using the F150's (20-pin) power fold window switch I picked one up at the junkyard P/N: FL3T-14B133-AHW.
The pinouts are identical.
To be continued.
