2024 Edge rattle noise from rear cargo trim panel
lasseventies
I also have the same exact noise. It's driving me crazy. I don't even need to be going 40mph for it to rattle. So annoying. Ford wanted $229 to do diagnostics on it yesterday. (2020 Ford Edge SEL 40K miles) it's been happening for years. If I tap it firmly with my hand, it will stop for a little while, then start again.
I've asked ever time I get an oil change and they always just told me they couldn't find anything. Please update me if you find what's wrong with yours.
  • Sad 1
Had a similar squeeking sould on my MKX at the front if the instrument panel (next to the windshield. Pried the strip up slightly and sprayed silicone spray. Stopped it for several years. Back again after several years ... 🤬
Try prying out slightly and spray with silicone.
Morgant513, I am guessing if you have the exact same issue, you have tried to tighten the trim screws holding the fabric liner to the fender well. As you can see from previous posts, this solved our issue. Please provide more detail if your issue is different.
  • 2 months later...
not much to add here...but I am glad I found this post.   I have a rattling sound somewhere in the right rear cargo panel just as lasseventies described in the first post.  Except mine seems to be at slower speeds and roughness of the road.  I will look into the above suggestions and see where it gets me.
