Morgant513 Posted January 23 Report Share Posted January 23 I also have the same exact noise. It's driving me crazy. I don't even need to be going 40mph for it to rattle. So annoying. Ford wanted $229 to do diagnostics on it yesterday. (2020 Ford Edge SEL 40K miles) it's been happening for years. If I tap it firmly with my hand, it will stop for a little while, then start again. I've asked ever time I get an oil change and they always just told me they couldn't find anything. Please update me if you find what's wrong with yours. 1 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 26 Report Share Posted January 26 Had a similar squeeking sould on my MKX at the front if the instrument panel (next to the windshield. Pried the strip up slightly and sprayed silicone spray. Stopped it for several years. Back again after several years ... 🤬 Try prying out slightly and spray with silicone. Quote Link to comment Share on other sites More sharing options...
STBEAST Posted January 27 Report Share Posted January 27 Morgant513, I am guessing if you have the exact same issue, you have tried to tighten the trim screws holding the fabric liner to the fender well. As you can see from previous posts, this solved our issue. Please provide more detail if your issue is different. Quote Link to comment Share on other sites More sharing options...
fh4ever Posted March 27 Report Share Posted March 27 not much to add here...but I am glad I found this post. I have a rattling sound somewhere in the right rear cargo panel just as lasseventies described in the first post. Except mine seems to be at slower speeds and roughness of the road. I will look into the above suggestions and see where it gets me. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 27 Report Share Posted March 27 While you're back there, check the tightness of the spare tire and Jack assy. If the wing nut loosened slightly, its possible that causing the squeek. Quote Link to comment Share on other sites More sharing options...
Cardi Posted 19 hours ago Report Share Posted 19 hours ago Tighten or replace the nuts for the rear license plate. That solved it on mine. It was driving me crazy 1 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted 7 hours ago Report Share Posted 7 hours ago (edited) Not sure how, but my rattle seems to be gone. Only after I pulled the entire panel off the rear hatch door for inspection and tried everything. I finally gave up and over time it went away. Find a bumpy road and have someone else drive. Sit in the back and start poking around. You should be able to locate it. I actually sat in the cargo area while my daughter drove. Not a safe thing to do, but I was losing my mind over this! When all else fails, just turn up the music. Edited 7 hours ago by STBEAST Quote Link to comment Share on other sites More sharing options...
