R. Shepler Posted March 22, 2025 Report Share Posted March 22, 2025 started the car hot in the driveway and all the coolant was immediately expelled from the system. no signs of leakage were visible before, but i did notice the reservoir was low a week ago and added coolant, maybe a quart. I've checked the oil and there is no sign of water in the oil. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 30, 2025 Report Share Posted March 30, 2025 When you say expelled, did you mean gone, or it dumped out on the ground? Quote Link to comment Share on other sites More sharing options...
Tim W. AZ Posted March 30, 2025 Report Share Posted March 30, 2025 5 minutes ago, enigma-2 said: When you say expelled, did you mean gone, or it dumped out on the ground? No mention of year or engine, but it sounds like a hose failure that started as a leak. Quote Link to comment Share on other sites More sharing options...
1004ron Posted March 30, 2025 Report Share Posted March 30, 2025 On 3/22/2025 at 3:13 PM, R. Shepler said: started the car hot in the driveway and all the coolant was immediately expelled from the system. no signs of leakage were visible before, but i did notice the reservoir was low a week ago and added coolant, maybe a quart. I've checked the oil and there is no sign of water in the oil. Time for some diagnostics - based on the sparse info provided best do a compression test - a blown head gasket could cause over-pressurization of the coolant system and expel the coolant. Quote Link to comment Share on other sites More sharing options...
1004ron Posted March 30, 2025 Report Share Posted March 30, 2025 32 minutes ago, Tim W. AZ said: No mention of year or engine, but it sounds like a hose failure that started as a leak. 2008 in the subject line and posted in the 3.5L section. 1 Quote Link to comment Share on other sites More sharing options...
