boostededge Posted September 10, 2025 Report Share Posted September 10, 2025 (edited) Changed the fluid in the 2019 Edge ST today. 45k miles on it, fluid looked a touch red still and didn't stink. No metal shavings. TFT up to ~185 Drained 4.7 qt / 4.44 L Added 5.28 qt / 5 L per FSM TFT up to >185 Pulled leveling plug and drained .68 qt / .650 L out (until fluid dripped down side of case) Added 1.05 qt / 1 L after leveling plug back in (??? its what FSM said so I did it ..) No idea if I was low to begin with but I followed the FSM exact. 2022 Edge ST Transmission Fluid Drain and Refill (2).pdf 2019_edge_transmission.pdf Edited September 10, 2025 by boostededge 3 Quote Link to comment Share on other sites More sharing options...
Chorster Posted January 16 Report Share Posted January 16 Hi BoostedEdge Thanks for sharing those FSMs. I have also done this procedure on my 2019 ST, and referred to the SM's you posted. The only procedure I did differently from the steps you posted is that I didn't top up the transmission fluid with 1L after filling with 6L then checking the level plug after reaching operating temperature since it seems that step is reserved for Initial Fills or for Transmissions that have been Overhauled. I didn't have mine overhauled or serviced, so I just did a simple drain/fill, filled with approx 6L, ran until operating temps were reached and checked the level through the level plug. In the attached references, it reads: 2022 ST FSM For Draining and Filling - Step 2. NOTICE: The following fluid amounts listed below are for initial fill only. 2019 Edge Transmission FSM - Filling Step 3. NOTE: Steps 3-8 apply if the transmission was overhauled. Did you have your transmission overhauled or a new one installed? I may be wrong so wanted to reach out. I monitored my temps on a long drive (2hrs) through some hilly terrain, max temps were 87C (188f), which seems to be similar to what you show here, so likely no overheating on either of our cases. But from what I understand, you don't want to overfill transmission units, nor do you want to be under by a liter. 2 Quote Link to comment Share on other sites More sharing options...
boostededge Posted January 21 Author Report Share Posted January 21 (edited) I think the 2022 FSM is a little more updated. The difference between the 5L and the 6L would be if the transmission was overhauled or if its just a drain/refill. If you added 6L at this step and the transmission was not overhauled I think its fine, there would just be more fluid draining out when you pull the leveling plug. Also if it was overhauled it still might be low when you pull the leveling plug so they have you add .25L at a time until it flows down the case correctly. From the 2022 FSM: 1. Transmission overhaul (includes main control and torque converter drain) Volume : 6.34 qt (6 L) 2. Main control overhaul or replace (with out transmission overhaul) Volume : 5.28 qt (5 L) So for the fill I put in 5L, got TFT up to 185 on jack stands, then pulled the leveling plug. The fluid looked like this: I let it drain right until it looked like this and then I installed the leveling plug: Then I buttoned everything back up and put in another 1L of fluid in as both the 2019 and 2022 FSM say to do. If you did not add that 1L, yours is underfilled. I put about 5K miles on the car since this flush and it shifts great. No weird shifts on the highway, no hunting for gears. It changes gears as it should. I also have Livernois updated tune but the tranny feels pretty good. Edited January 21 by boostededge 2 Quote Link to comment Share on other sites More sharing options...
Jetboy47 Posted January 21 Report Share Posted January 21 The section below that which has "Transmission Fluid Level Check" also tells you to add a liter after checking and installing back the level plug. 2 Quote Link to comment Share on other sites More sharing options...
boostededge Posted January 22 Author Report Share Posted January 22 23 hours ago, Jetboy47 said: The section below that which has "Transmission Fluid Level Check" also tells you to add a liter after checking and installing back the level plug. Great info! 1 Quote Link to comment Share on other sites More sharing options...
Chorster Posted January 22 Report Share Posted January 22 (edited) Thanks all, I appreciate the information. Considering I didn't top off with one liter after getting the correct amount of fluid spill from the inspection plug/level plug at operating temp, I topped off with 1L this morning. Admittedly, my 2019 ST has been driven about 30k Km's in this condition, and I didn't experience any shuddering, high temps, tranmsmission pump DTC's. Shifting has been smooth, perhaps due to the the PC being reprogrammed as per TSB 20-2190 at the beginning of this 30k Km interval. Just came back from a test drive after topping off with the extra liter, didn't feel anything different while engine was getting up to temp under regular load, or while driving while at operating temp. Maybe deceleration was a bit smoother than usual, but hard to tell since roads have been snow-covered for the past few days and are now cleared up. I will monitor over the next few trips, and will most likely do another drain/fill. will capture some pics of the fluid and post here as follow-up. Truly hoping that I didn't incur too much wear considering I had not topped off the 1L after obtaining the "correct" trans level plug as per the FSM's images from boosted's images above! Edited January 22 by Chorster 1 Quote Link to comment Share on other sites More sharing options...
boostededge Posted January 23 Author Report Share Posted January 23 I'm sure everything is fine. Most people don't even read the FSM, don't know about the full +1L and just do a drain and fill. Smoothness on decel is one thing I've noticed as well. I also had a slight vibration at idle depending on what RPM the vehicle was idling at. That appears to have gone away now or is deceased after the drain/fill/+1L. Quote Link to comment Share on other sites More sharing options...
STBEAST Posted January 25 Report Share Posted January 25 As ignorant as I am, why is a transmission fluid change so complicated. An engine oil change is so easy compared to a transmission service. 2 1 Quote Link to comment Share on other sites More sharing options...
boostededge Posted January 25 Author Report Share Posted January 25 17 hours ago, STBEAST said: As ignorant as I am, why is a transmission fluid change so complicated. An engine oil change is so easy compared to a transmission service. Thought the same dang thing 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted February 2 Report Share Posted February 2 On 1/25/2026 at 12:28 AM, STBEAST said: As ignorant as I am, why is a transmission fluid change so complicated. An engine oil change is so easy compared to a transmission service. So you have to go to the dealer for service 1 1 Quote Link to comment Share on other sites More sharing options...
garycrist Posted February 2 Report Share Posted February 2 This is a whole lot easier than changing fluid on a C4. Then bumping the engine over to find the drain plug and draining the Torque Converter. Not to mention somewhere between 10 to 13 Quarts. Did I forget the refill procedure? To lazy to type it out! These things are easy to DIY just HOT! 1 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted February 2 Report Share Posted February 2 (edited) I feel pretty confident doing my first PTU and RDU service. I'll probably take it to my dealer for the transmission service. More so, just concerned that they actually do it. And do it right! Being on this Forum gives me so much valuable information. Including a lot more confidence in doing some of my own maintenance. Thanks to everyone! Edited February 2 by STBEAST 2 Quote Link to comment Share on other sites More sharing options...
garycrist Posted February 3 Report Share Posted February 3 You can do the tranny at the same time! Pop 2 plugs, drain, add the fluid (Ford has built-in a handy funnel holder), drink your favorite waiting beverage for the fluid to reach 180 F about 10 minutes and install the site plug! 2 Quote Link to comment Share on other sites More sharing options...
Ensferi Posted 6 hours ago Report Share Posted 6 hours ago Hello on the 2.0 eco blue diesel 175 kw is the same to add 1 L after level check ? In eu manual there is just 250 ml i think, so should i add 1 l or just the 250 ml ? its same 8f57 just different engine RB_8F57.pdf Quote Link to comment Share on other sites More sharing options...
