JPJMustang Posted 13 hours ago Report Share Posted 13 hours ago (edited) Had the "proverbial" water pump fail The engine locked up - water in the oil pan expect that the bearing are shot If Im going to pull the engine and do bearings - might was well take a look at a rebuild Just had the transmission rebuilt - so....... If it worth rebuilding (saw a kit for $580 from Ford) https://www.ford.com/product/35l-na-v6-rebuild-kit-1-p2938618647 Or just get a used engine and swap out? JPJM Edited 13 hours ago by JPJMustang SPELLING Quote Link to comment Share on other sites More sharing options...
edjunior Posted 5 hours ago Report Share Posted 5 hours ago For $580, I think I would do the rebuild. Especially if you are doing the labor, or have someone that can do it relatively inexpensive. With a used engine, even if you could find one as cheap as that rebuild kit (and possibly labor), you take a big chance not knowing what you will get. With the rebuild, you know what you have in the engine and the quality of the work. Just my 2 pennies1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted 5 hours ago Report Share Posted 5 hours ago What's in that kit is what I'd call a "refresh" not a "rebuild". What's the mileage? Locked up due to lack of bearing lubricant would also damage the crank and would need machining or at least polishing, then what about pistons and rings? A used motor with similar mileage would likely soon need a rebuild? Quote Link to comment Share on other sites More sharing options...
