2018 broken sun shade roller for panoramic vista sunroof bamr
This plastic bracket for the sun shade broke.
Can anyone provide part numbers and instructions on how to replace?
(There appear to be no topics already established for this issue.  I've searched the forum manually by scrolling through the topics and by keyword searches in the sections for "Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers" and "2015+ Edge & MKX Generation II 2017-2018 Edge & MKX" and have only found topics about the glass and it's track.  While I've not checked the dealership yet, I do not see parts available beyond 2014.)
As far as instructions on how to replace, have you checked other platforms other than there Ford Edge Forums?  I suggest a Google search.
Instructions for replacing the roof panel seal requires complete removal of the sun roof to perform.  Could be this repair will be the same procedure.
From the instructions, it's nt overly difficult, but time consuming.
I've searched youtube and not found anything specific to a ford sunshade.  I've not gone into other ford model forums yet.
Can you lmk where to find those instructions for replacing the roof panel seal?
On 3/28/2026 at 12:11 PM, enigma-2 said:
Try contacting the Sunroof Doctor we site. They provide / manufacture parts for Ford/Lincoln moonroofs.
https://www.sunroofdoctor.com/
Sunroof DR says a dealer only item right now and is generically referred to as:
Sunroof Cable - Ford (FT4Z-58500B01-B)
https://ford.oempartsonline.com/oem-parts/ford-sunroof-cable-ft4z58500b01b
If anyone knows the location within the forum on how to safely remove the headliner, I'd appreciate the link.  I know the four grab handles don't have any exposed fasteners.
Thanks for your replies
5 hours ago, Samurai Edge said:
I was confused with your original post.  I thought you wanted to replace the actual sunroof panel seal, not the sunshade cable.
Quite honestly, this took me 15 seconds to find.     https://duckduckgo.com/?q=how+to+replace+ford+edge+sunroof+shade&t=h_&ia=web
This will provide you with lots of options on the Ford Sunshade repair.
The pictured plastic bracket for the sun shade broke.  I'm told it's attached to a "sunroof cable."
I see the search term you used in your duck duck go link is "how to replace ford edge sunroof shade" and while infinite results are displayed, none of them are actually for replacing this cable.  If you can direct me to something specific relating to my issue, I'd appreciate it.
New searches for "sunroof cable" do not reveal anything useful in or outside of this forum.  The lack of info available on this leads me to believe it rarely breaks, or everyone lets the dealer fix it, or it's so easy to replace that nobody bothers mentioning it.
It's looking like I'll need to drop the headliner, begin removing anything below the cable, and figure out how to get the new cable aligned with the other cable so they're in sync and don't pull the shade unevenly.
I'll consider posting the fix in the forum once I'm done.
