Got 2 Posted March 28, 2025 Report Share Posted March 28, 2025 Second post for me. (First was a reply ) 2020 2.0 Eco. I finally understand the block/coolant issue that has plagued the ecoboost for some time. Huge thanx to Fordtechmakuloco! As he points out so well, the block was improved by dropping the coolant "slit" between cylinders and going to a port/tube. That was "during" the 2020 model year. Sooooo...I have just updated from my 2012 3.7 workhorse (really miss it )to a 2020 2.0 Eco. How do I find out if I have the flawed or fixed block? VIN tells me it is an Oakville build production sequence A51877 Thanx Much for any good news, or at least to be prepared for bad news... Dave Wilson 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted March 28, 2025 Report Share Posted March 28, 2025 3 hours ago, Got 2 said: Second post for me. (First was a reply ) 2020 2.0 Eco. I finally understand the block/coolant issue that has plagued the ecoboost for some time. Huge thanx to Fordtechmakuloco! As he points out so well, the block was improved by dropping the coolant "slit" between cylinders and going to a port/tube. That was "during" the 2020 model year. The Edge got a new engine configuration with a new block in MY 2019 (other vehicles got a revised block mid year 2019). The new 2.0 it got has things like an EGR cooler (which was problematic first couple of years, with a leak and TSB), and the block no longer has slits to the head, as you mention, but a round port. Quote Link to comment Share on other sites More sharing options...
detoothaker Posted March 31, 2025 Report Share Posted March 31, 2025 So I have the common coolant intrusion issue in my 2018 ford edge 2.0 eco boost. I have a letter to send to Ford Motor company to see what they will do to fix this issue. It is not under any warranty as it just reached over 100k miles. Does anyone know who I could reach out to in order to be sure my letter and complaint goes to the right people. I live in Maine and am finding it hard to find a dealership that will check into this issue for me. Thanks in advance. 1 Quote Link to comment Share on other sites More sharing options...
Ant Posted August 3, 2025 Report Share Posted August 3, 2025 So it all started with coolant getting into cylinder 1. I called my ford dealership to see what they recommend and they said long block replacement. I asked for a quick quote for engine replacement and was around 15k. I’m sorry but the car isn’t worth that. So I decided to replace the head gasket and go from there. Now with that all done car stars idle fine but when driving it doesn’t want to get up to speed (loss of power). 1 Quote Link to comment Share on other sites More sharing options...
Ant Posted August 5, 2025 Report Share Posted August 5, 2025 Now I’m getting the P0012 code. I did buy 2 new VVT124 installed them and that when the P0012 code came on. Has anyone else have this issue. I don’t really want to just start replacing parts that aren’t needed. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 5, 2025 Report Share Posted August 5, 2025 8 minutes ago, Ant said: Now I’m getting the P0012 code. I did buy 2 new VVT124 installed them and that when the P0012 code came on. Has anyone else have this issue. I don’t really want to just start replacing parts that aren’t needed. That's why we promote diagnostics, to avoid replacing parts that aren't needed. What prompted you to replace the VVT124's ? Quote Link to comment Share on other sites More sharing options...
Ant Posted August 5, 2025 Report Share Posted August 5, 2025 4 minutes ago, 1004ron said: That's why we promote diagnostics, to avoid replacing parts that aren't needed. What prompted you to replace the VVT124's ? I applied voltage to them to test and they weren’t functioning so instead of taken them apart I figured buying news ones would be best. Quote Link to comment Share on other sites More sharing options...
Ford Edge owner 2 Posted September 23, 2025 Report Share Posted September 23, 2025 I've just experienced the coolant loss isue with my 2017 ford edge ecoboost at 61000 miles Anyone know else experiencing this? How are ford denying that this is an intrinsic defect. Quote Link to comment Share on other sites More sharing options...
tommy419 Posted September 24, 2025 Report Share Posted September 24, 2025 I have a 2019 Ford Edge Eco boost. It's losing coolant, no obviously leaks no overheating. The heat also does not work, but Both heater core hoses get hot The oil is clean and there's no white smoke coming out of the Exhaust. 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted September 25, 2025 Report Share Posted September 25, 2025 13 hours ago, tommy419 said: I have a 2019 Ford Edge Eco boost. It's losing coolant, no obviously leaks no overheating. The heat also does not work, but Both heater core hoses get hot The oil is clean and there's no white smoke coming out of the Exhaust. Do you have the Check Engine Light on? The 2019 has a redesigned block and engine compared to the one that exhibits coolant intrusion. It could be related to the EGR cooler. https://static.nhtsa.gov/odi/tsbs/2020/MC-10177867-0001.pdf Quote Link to comment Share on other sites More sharing options...
Ford Edge owner 2 Posted October 4, 2025 Report Share Posted October 4, 2025 On 9/23/2025 at 2:59 AM, Ford Edge owner 2 said: I've just experienced the coolant loss isue with my 2017 ford edge ecoboost at 61000 miles Anyone know else experiencing this? How are ford denying that this is an intrinsic defect. Yep mine has also just gone, problem started at 61000, silly diagnostics and repairs that didn't address the issue, now being quoted a gasket change and potentially engine replacement Quote Link to comment Share on other sites More sharing options...
Starcr182 Posted October 4, 2025 Report Share Posted October 4, 2025 I recall mine happened at roughly 65000 miles. If you have a 2017, that’s not gonna fix the problem you need to replace the engine with an engine from 2019 or later as it is a redesigned block. Unfortunately, due to the market of cars now back when I did it if I would’ve known the value of my car would drop to where it is now. Rough pill to swallow. Quote Link to comment Share on other sites More sharing options...
oskar27 Posted October 4, 2025 Report Share Posted October 4, 2025 Mine is 2016 Titanium with the 2.0 EcoBoost and just turned 60K kilometers. No problems so far, love the car, but I'm waiting to see when it will happen to me too...... Quote Link to comment Share on other sites More sharing options...
WillM Posted October 21, 2025 Report Share Posted October 21, 2025 (edited) I just got this code and what you experienced is exactly what I experienced. During cold start it starts rough. I also noticed that it need some coolant. So what was it? Should I take it to the dealer or local shop? I have extended warranty. Edited October 21, 2025 by WillM 1 Quote Link to comment Share on other sites More sharing options...
PeteVB Posted February 20 Report Share Posted February 20 Hi all. I know this has been covered to death, but I had an idea. I have a friend with a 2016 Edge 2.0l ecoboost with 106k miles, Cleveland engine. It just started showing signs of the dreaded head gasket failure. #1 spark plug has burnt coolant on it, intermittent P0301 code, rough idle on startup. She's on a tight budget and bought the car used from a private party, I seriously doubt any dealer is going to swap the long block for what she can afford, or for less than what the car is worth for that matter. I did some research. Seems that Mustangs with the 2.3l of similar vintage have the same issue, same cause, particularly when modded. I found a race shop on the web that sells a kit that supposedly fixes the problem. It consists of a set of ARP head studs and a modified head gasket. I looked at the factory head bolts and they seem pretty wimpy. So bad that they're even fully threaded. I checked the part number and the 2.0l uses the same studs as the 2.3, so the ARP kit should work, although APR does not list the 2.0l as an application for them. There are 2 ARP kits available, Pro Series (251-3701) for around $110 or CA625+ (251-4303) for about $400. The race shop sells the CA625+ variant. I see that Ford lists 2 head gaskets for her car. One that appears to be the original factory installed part (FB5Z-6051-A), and one that looks to be an improved version (HS7Z-6051-A) I couldn't find any notes regarding supersession or usage. It could be that the later version is intended for the retrofitted long block (J2GZ6006E), but I'm not sure. The older gasket has gaps in the sealing material that correspond with the slots in the block between the cylinders, the new one doesn't. Given the situation, I'm considering replacing the head gasket with the improved version and installing the CA625+ studs. I'm wondering if anyone has tried this approach before, and, if so, what were the results? If someone can confirm that the HS7Z-6051-A head gasket is compatible with the original engine block I would appreciate it. Thanks Pete Quote Link to comment Share on other sites More sharing options...
Biker Posted February 26 Report Share Posted February 26 On 8/29/2024 at 8:04 AM, HomeLander said: Mechanic here. My wife’s car is a 2017 Lincoln MKC that we bought early in 2020 just before all of this information came out about how terrible the 2.0 design with the grooved cylinder walls and head gaskets were. 71k miles - no extended warranty- still has a car payment. Now we have a po301 code. Cylinder one misfire and it slowly losing coolant. I took out all 4 coil packs and plugs. Checked each cylinder with a borescope. Cylinder one appeared very dirty compared to the others - however no sign of coolant in the cylinder and the plug looked identical to the others. I moved the plug and coil pack from 1 to 2 in hopes that the misfire was a coil pack. The misfire came back the next morning on a cold start and unfortunately is still on cylinder one. What I believe id happening is that while the engine is at operating temp - the head gasket is sealing properly - then as the engine cools of when its shut down - the gasket shrinks and shifts which causes it to leak coolant into the cylinder. Then on startup it misfires momentarily as the coolant is burned off. While the car is running at operating temp it is fine again. Of course this will become much worse at anytime now as the gasket fails farther. So as a mechanic - I will tell everyone that I know - do not under any circumstance buy a ford product. They will not stand behind their cars and refuse to issue a recall to help their customers. After warranty runs out you will be on the hook for a new engine - in our case at 71k miles. I told my wife that this car would be a safe reliable and dependable car - now we will be stuck with a paperweight that still has a payment. Good diagnosis, that is what is happening. Pressurize the system while cold to confirm. It does suck, but as a mechanic, I would yank that little engine myself and do the short block replacement. Exhaust every avenue politely with corporate first and see if they will bend. Quote Link to comment Share on other sites More sharing options...
WillM Posted February 26 Report Share Posted February 26 (edited) 8 hours ago, Biker said: Good diagnosis, that is what is happening. Pressurize the system while cold to confirm. It does suck, but as a mechanic, I would yank that little engine myself and do the short block replacement. Exhaust every avenue politely with corporate first and see if they will bend. We had the same issue, and thankfully I had purchased the extended warranty, so the repair was covered. That said, I would never buy a Ford again. The dealer charges $200 just to diagnose anything — even something as simple as a stuck seat belt. In my case, they didn’t even attempt to repair it. They just recommended full replacement. I’ve had issues with two seat belts: Front driver side gets stuck during the hot summer months. Rear seat belt stays stuck. I also had the tailgate lock fail, which they replaced. For a vehicle with under 50k miles, I’ve spent more on repairs than I did on both my Honda Pilot and Lexus at the same mileage. That’s unacceptable. Edited February 26 by 1004ron Quote Link to comment Share on other sites More sharing options...
Dysfun2 Posted Saturday at 05:45 PM Report Share Posted Saturday at 05:45 PM I inherited a 2018 Ford edge eco-boost 2.0L with very low miles. I have come across the reports of coolant intrusion and total engine failure. From what I can tell, it sounds pretty significant with a high price of repair. I was wondering what percentage of these engines have the failure. Trying to decide if I should just sell it now or try to stick it out as my long-term vehicle. 1 Quote Link to comment Share on other sites More sharing options...
edjunior Posted 8 hours ago Report Share Posted 8 hours ago (edited) If it is inherited, that would mean it did not cost you anything other than inheritance and registration taxes and such. I have a 2016 with the 2L engine. I don't know if it's the same run as the 2018's, but I got mine a couple of years ago, and it now has just shy of 100K on it. So far it has been no problem at all. I don't drive it a lot, but my son drove it quite a bit for a while until he got his new car. You read about the issues with it, but you didn't read all the thousands of others who didn't have any problems, because people usually don't post until they have a problem. Sure it could drop on you at any time, but that could be said of any car. Since it cost you very little to get, if it did that, you stand to lose very little. If you like the car otherwise, I would say keep it and maintain it, and enjoy it. Good luck! Oh, and welcome to the forum! Edited 8 hours ago by edjunior 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted 58 minutes ago Report Share Posted 58 minutes ago @Dysfun2 Welcome. It might be worth contacting Ford Corp to see if there's any compensation on the table for this latent defect. Quote Link to comment Share on other sites More sharing options...
