Electrical issues - Which electrical Diagrams to purchase?
edged-on
I have a 2015 for Edge with a no-crank, no-start issue with the following codes:
p0073, p0122, p0223, p0740, p1289
tracing wires from the temp sensor & throttle position sensor back to the ecu:  wiring is good. These were the easiest to get to and test.
Which wiring diagram suppliers do you recommend ordering from?
thank you.
Thank you for the link.
Update & Resolution:
Looking through the electrical diagrams, the yellow sig return wire seemed to be the culprit,  but I have no proof.
After exhaustive connectivity checks, relay swapping, fuse verification testing, plug connector contact cleaning:  It just fired up and purrs like a kitten.
I believe the car just wanted a break;  to be jacked up on the stands in the garage for a month or so.
