Chipster Posted September 5 Report Share Posted September 5 (edited) I tried to schedule an appointment for the brake hose replacement on my 2015 Edge 2 months ago and the dealer said they had not gotten approval from Ford to do the work. I called the parts dept. just to see if they had the new hoses and was told they had them in stock. What's going on here? Has anyone else had this problem getting the rear brake hoses replaced? Edited September 5 by Chipster Quote Link to comment Share on other sites More sharing options...
1004ron Posted September 6 Report Share Posted September 6 Carfax shows "Status: Remedy Not Yet Available". Could it be that the local Ford parts department has stock of the old hoses? Quote Link to comment Share on other sites More sharing options...
Chipster Posted Tuesday at 07:10 PM Author Report Share Posted Tuesday at 07:10 PM Ok, I just got this "remedy available" notice from Ford. It seems replacement is only available now if the rear brake hose(s) are damaged or are leaking. They will inspect them first, and if found to be damaged or leaking will replace them. Apparently Ford will will repair later if a failure shows up in a 15 year window. I wonder if that is 15 years from new? Quote Link to comment Share on other sites More sharing options...
edjunior Posted yesterday at 02:37 AM Report Share Posted yesterday at 02:37 AM I just got this letter today, saying the fix is available. I just happened to put my Edge in the shop a couple of days ago to fix another TPMS sensor, and have another one replaced under warranty (they replace it a few months ago, and it failed). I had them check the recall also, and I don't know if they found it bad or not, but they replaced it anyway. So I should be good to go for the potential brake problem, and hopefully all my TPMS sensors. I will be giving this car to my son, who will use it until he gets back on his feet, then give it to his son. That was the deal I made with him. So I wanted to make sure the car was all serviced up and as good as can be. Quote Link to comment Share on other sites More sharing options...
Chipster Posted yesterday at 07:21 PM Author Report Share Posted yesterday at 07:21 PM 16 hours ago, edjunior said: I just got this letter today, saying the fix is available. I just happened to put my Edge in the shop a couple of days ago to fix another TPMS sensor, and have another one replaced under warranty (they replace it a few months ago, and it failed). I had them check the recall also, and I don't know if they found it bad or not, but they replaced it anyway. So I should be good to go for the potential brake problem, and hopefully all my TPMS sensors. I will be giving this car to my son, who will use it until he gets back on his feet, then give it to his son. That was the deal I made with him. So I wanted to make sure the car was all serviced up and as good as can be. That is interesting that they changed out the rear hoses.(I wish you knew why?) I was told that mine would be changed out ONLY if they were leaking or damaged, but the old ones will be warrantied for another 5 years if they do start to leak or are damaged. I was not real happy to hear this because a failure at speed will / might be VERY dangerous. Quote Link to comment Share on other sites More sharing options...
edjunior Posted 18 hours ago Report Share Posted 18 hours ago 7 hours ago, Chipster said: That is interesting that they changed out the rear hoses.(I wish you knew why?) I was told that mine would be changed out ONLY if they were leaking or damaged, but the old ones will be warrantied for another 5 years if they do start to leak or are damaged. I was not real happy to hear this because a failure at speed will / might be VERY dangerous. My service department here has been really good when it comes to service bulletins and recalls. I've had a couple before on other vehicles that were the same language, change only if observed to be defective, or whatever. But they changed it out anyway. I only had one time they would not work with me, and that one still kind of torques my lugnuts a bit. Anyway, I'm glad they did it. I'd like to have the car in as good shape as possible handing it down to my son and grandson. It makes me feel better. Quote Link to comment Share on other sites More sharing options...
