vincent k Posted September 18 Report Share Posted September 18 help whats this noise , its coning from the top of the engine , i pulled the valve cover to check upper timing chain but everything seems tight. dosent seem to be coming frop flex plate area. help 2.0 ecoboost 170,000 miles 20260917_224247.mp4 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted September 19 Report Share Posted September 19 (edited) Is this your own vehicle and if so have you noticed any performance impact at the onset of the noise? As a test you could run it with the serpentine belt removed. Edited September 19 by 1004ron Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted September 19 Report Share Posted September 19 How long has this noise been an issue? Other than that, you haven't specified anything about vehicle maintenance, etc. Quote Link to comment Share on other sites More sharing options...
fh4ever Posted September 20 Report Share Posted September 20 My 2024 has a similar sounding noise but certainly not near as loud. I can't hear it inside the car, but pop the hood... and it sounds like a noise that not suppose to be there on a newer car. I will try to pin point mine with a sethascope and I will be asking the dealer about it too. I read somewhere the high pressure fuel pump can be noisy like this. my daughter's 2006 focus has a similar noise and intensity and it almost sounds like the intake valves clattering under the valve cover. Turns out the intake manifold runner has some wear and it clatters quite loudly. Seems this was an issue in those early focus's. Do let us know what you find out on yours. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted September 20 Report Share Posted September 20 Is this one of the models where Ford did away with the aesthetic / acoustic cover? Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted September 21 Report Share Posted September 21 On 9/20/2026 at 6:51 AM, fh4ever said: My 2024 has a similar sounding noise but certainly not near as loud. I can't hear it inside the car, but pop the hood... and it sounds like a noise that not suppose to be there on a newer car. I will try to pin point mine with a sethascope and I will be asking the dealer about it too. I read somewhere the high pressure fuel pump can be noisy like this. my daughter's 2006 focus has a similar noise and intensity and it almost sounds like the intake valves clattering under the valve cover. Turns out the intake manifold runner has some wear and it clatters quite loudly. Seems this was an issue in those early focus's. Do let us know what you find out on yours. Are you sure what you are hearing is not just the fuel injectors? Quote Link to comment Share on other sites More sharing options...
fh4ever Posted September 21 Report Share Posted September 21 Port injectors are normally pretty quiet. I don't know how loud the direct injection injectors are suppose to be. My 2024 does seem noisy to someone who has never had direct injection, and kinda matches the ticking sound and frequency like in vincents video, just not as loud. I dont know how I missed that when I was buying the car. I did not pick up on it until about few months ago when I raised the hood, and it seemed a lot louder then, maybe because it was the fist time hearing it. Vincent... look between the two wiring labels (the top label has K17 on it), there is something that looks like a oil "bubbling" between the intake manifold, head and valve cover. Is that an illusion? 1 Quote Link to comment Share on other sites More sharing options...
fh4ever Posted September 24 Report Share Posted September 24 Vincent K.... any updates? Ford technician listened to my "clacking noise" today. We have much cooler temps today and the noise had really quietened down. He stated what he heard was normal. 1 Quote Link to comment Share on other sites More sharing options...
