vincent k Posted Friday at 03:59 AM Report Share Posted Friday at 03:59 AM help whats this noise , its coning from the top of the engine , i pulled the valve cover to check upper timing chain but everything seems tight. dosent seem to be coming frop flex plate area. help 2.0 ecoboost 170,000 miles 20260917_224247.mp4 Quote Link to comment Share on other sites More sharing options...
1004ron Posted Saturday at 03:06 PM Report Share Posted Saturday at 03:06 PM (edited) Is this your own vehicle and if so have you noticed any performance impact at the onset of the noise? As a test you could run it with the serpentine belt removed. Edited Saturday at 04:29 PM by 1004ron Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Saturday at 03:13 PM Report Share Posted Saturday at 03:13 PM How long has this noise been an issue? Other than that, you haven't specified anything about vehicle maintenance, etc. Quote Link to comment Share on other sites More sharing options...
fh4ever Posted yesterday at 10:51 AM Report Share Posted yesterday at 10:51 AM My 2024 has a similar sounding noise but certainly not near as loud. I can't hear it inside the car, but pop the hood... and it sounds like a noise that not suppose to be there on a newer car. I will try to pin point mine with a sethascope and I will be asking the dealer about it too. I read somewhere the high pressure fuel pump can be noisy like this. my daughter's 2006 focus has a similar noise and intensity and it almost sounds like the intake valves clattering under the valve cover. Turns out the intake manifold runner has some wear and it clatters quite loudly. Seems this was an issue in those early focus's. Do let us know what you find out on yours. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted yesterday at 11:35 AM Report Share Posted yesterday at 11:35 AM Is this one of the models where Ford did away with the aesthetic / acoustic cover? Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted 1 hour ago Report Share Posted 1 hour ago On 9/20/2026 at 6:51 AM, fh4ever said: My 2024 has a similar sounding noise but certainly not near as loud. I can't hear it inside the car, but pop the hood... and it sounds like a noise that not suppose to be there on a newer car. I will try to pin point mine with a sethascope and I will be asking the dealer about it too. I read somewhere the high pressure fuel pump can be noisy like this. my daughter's 2006 focus has a similar noise and intensity and it almost sounds like the intake valves clattering under the valve cover. Turns out the intake manifold runner has some wear and it clatters quite loudly. Seems this was an issue in those early focus's. Do let us know what you find out on yours. Are you sure what you are hearing is not just the fuel injectors? Quote Link to comment Share on other sites More sharing options...
