Fuel Octane Choice
STBEAST
I know there are a few previous threads on this topic. I bought my ST brand new and run 91 octane. My thinking is most all performance vehicles require high octane for best performance and to minimize the chance of engine knock, which over time can cause damage. My owner's manual states that my vehicle is designed to run on 87, but.......
I have never tried 87 and never intend to. But if I drove the car conservatively it should be ok? Gas is getting very expensive here in California!
When I bought the vehicle, I planned on using premium fuel. Mainly because it is turbocharged (two turbos!) and is considered a performance vehicle.
I have heard on more than one occasion that people notice a difference in performance when they use a lower octane fuel.
That is because the knock sensor detects excessive knock and adjusts the timing, fuel injection duration etc. to protect the engine from damage.
Most people might not even hear it or know it is happening.
That should be enough for anyone. Of course, at the time I had no idea I would be paying 6 bucks a gallon for gas!
Saving a few bucks likely not worth it in the long run.
The 2.7 in the F-150 and Bronco show on the dyno a loss of 15-17hp from the factory 325 when running 87 octane. Ford rates the HP with premium fuel (and mpg with 87).
When premium was $.20 a gallon more I would run it in my premium recommended vehicles. A slight SOP feeling of better power/driving, and probably due to changes in driving dynamics, better mileage (but even at $.20 a gallon more expensive it rarely was a wash, and more expensive to run premium). Currently most places local to be premium (91 here) is $.80 to $.95 more than 87 (and for those that care, $1.25 more than Unleaded88).
Personally I don't miss the 10 hp I lose running 87 octane in my SEL.
But is it ok? You are noticing a loss of horsepower due to running low octane fuel.  I get it. But if the engine is telling you "Run low octane get low performance" why is it even an option. To save a few bucks? Maybe worth it on a standard edge. But on an ST maybe better to run the best.
Not much discussion on using 89 and meeting half way.   ???
I don't know where you got that info on the differences in dyno numbers between 87 octane.  15 - 17 HP compared to what?
As far as my reasoning for staying with 93 octane:
  - Yes, there is a felt performance difference
  - More importantly, the motor just runs better overall - Smoother, more responsive, etc.
There are quite a few posted dyno runs for F-150 and Bronco owners using 87 octane. They show that compared to the numbers from Ford, which are done with 93 octane, are down around 15 hp, some compare same vehicle 87 and 93.
I don't really understand how the standard base engine from a truck (and not even the current generation) is considered high output and requires 93 or it is being abused. For the chassis it is on, it is the HO option, but not pushing any limits there. 10 extra hp?
Ten extra HP doesn't really amount to much.
One just has to remember if they are comparing apples to apples.
In this case, as long as the numbers from Ford were from a dyno, and not advertised numbers you see in the brochures, then they are a little more comparable.
If one is using the same vehicle, on the same dyno, on the same day, at the same time of day, by the same operator, using fuel from the same source, then the numbers would be directly comparable.
There area lot of variables to consider when attempting to compare dyno numbers.  People always don't understand this.
The other thing to remember is that if you are comparing advertised numbers to dyno numbers, as opposed to actual dyno numbers, there is a parasitic drivetrain power loss between the motor and the wheels.
