2022 SEL with 92k, multiple codes
Summers22
Trying to help my daughter with her car. Multiple codes, reduced power and very sluggish acceleration up until 40mph. No check engine light. List of codes:
ABS Antilock braking system :
DTC Description Status
U0140:00:20 Lost Communication With Body Control
Module
CMDTC
U0265:00:20 Lost Communication with Image
Processing Sensor A
CMDTC
U2107:00:68 Collision Mitigation By Braking CMDTC
U3003:16:60 Battery Voltage CMDTC
PCM Powertrain Control Module:
DTC U0284:00:68 Description Lost Communication with Active Grille Air
Shutter Module 'A' CMDTC
On 10/31/2026 at 12:13 PM, 1004ron said:
If the alternator is working I don't see how the bad battery will cause the symptoms you describe.
All depends on how much the OP's daughter has been driving the car.  This could again be one of those things where there is a battery drain due to sensors on 24/7 even while the car sits unused.  The drain can cause all sorts of weird codes to pop up.
If he comes back and says, " It's all fixed " then issue solved as well as the culprit.
