Counterfeit Motorcraft Spark Plugs
omar302
I recently faced a major knocking issue in the 2.7 after a Spark Plug change (SP594).
I thought I got a good deal on them on eBay only to find out they were counterfeit and are most definitely no iridium.
The knocking was so bad that the pcm through a code for the crankshaft position sensor, P0339. Bought a new spark plug set from the dealer, which looked iridium, and the issue was fixed.
I didn't know about the counterfeits being sold, but after facing the issue immediately after a spark plug change and then searching online I stumbled upon several posts of the issue. This is one from Ford Tech Makuloco.
So just beware.
