edgemaster
    2
Everything posted by edgemaster
  1. Guys, I'm contemplating replacing the turn bulbs with LEDs but I don't want to install those resistors and turn electricity into heat. Is there a flasher relay that would support that? I find conflicting info online about a flasher relay or some sort of electronic flasher. Which one does a 2009 Edge Ltd have?
  2. I got me one of those gadgets and ran the relearn procedure. All is OK now. If the message pops up again in a few weeks, which I totally expect, one of the sensors is bad, right?
  3. I have received those headlights and I am somewhat confused about the electrical wiring. There is a red and black wire and two pairs of black/white wires, one pair at the bottom and the other pair at the top of the unit. Also there are 2 resistors in their heat sinks. Where do all the wires and the resistors go go? Thanks, Ed
  4. Guys, just received those new headlights that I had mentioned in an earlier post. They came with 2 resistors in case the blinker bulbs are LEDs. I'm planning to use the stock bulbs for the time being so I don't have to install those resistors, right? However, If I planned to install LED blinker bulbs, do I have to do it on all fours or can I mix? Do I need 4 resistors or just 1 per side? Another question: there are 2 pairs of white/black wires coming out of the unit, one pair on top, the other pair on the bottom. What are they for? I had contacted the seller but the support people don't seem to know what they're talking about (same gal that told me about 260000 lumens per bulb).
  5. I spent $1600 so I m assuming they are new. I'm sure, if I'd ask them they would swear up and down they were new. I've ordered one of those gadgets that you recommended. Thanks for all the input.
  6. As I said in my original post, I was there about a month ago with that same message in the dash and they did reset or relearn or whatever and the message was gone. So, I'm pretty sure they're installed.
  7. It was Discount Tire and they told me they had installed the sensors.
  8. Thanks, my Edge is a 2009 LTD. I'm assuming the sensors are new, installed a year ago with the tires/rims.
  9. About a year ago I had new tires/rims installed. A month ago this "TPM sensor error" message showed up in the dash. The tire guys told me all sensors are OK, reset them via OBD II. Now the message is back again. It appears that one of the sensors is not OK, right? Do I have to live with that resetting every couple of weeks? It's an 80mi roundtrip each time.
  10. So, with 2200 and 2600 lumens, I'd be on the safe site. Thanks for the info.
  11. I questioned their liberal usage of the Zeros and they finally corrected the figures to 2200 and 2600 respectively. Still, I would be interested in learning what the stock lumen figures are. Apparently nobody knows.
  12. I just found out from the vendor of the above headlamp assemblies this: Low beam: 220,000 lumens Hi beam: 260,000 lumens Can that be true?
  13. Thanks for the details, very much appreciated. So, these headlights (https://www.ebay.com/itm/304487583413?fits=Year%3A2009%7CModel%3AEdge%7CMake%3AFord&_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20220310133107%26meid%3Da9a0b26ba0b14372a50a0d43e19c1968%26pid%3D101196%26rk%3D2%26rkt%3D12%26sd%3D371701026992%26itm%3D304487583413%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv9PairwiseWithPLXWebFitmentFilterConfirmFitSignal%26brand%3DSpec-D+Tuning&_trksid=p2047675.c101196.m2219&amdata=cksum%3A304487583413a9a0b26ba0b14372a50a0d43e19c1968%7Cenc%3AAQAHAAABIAzdIKOcP6rVYsexH8mCu6YYN0SdXxqICy66h220Th%252FC6c6aZpFIEmATXPImB6gOXUa%252FXvip3BRuztnBr5L4o8yl3taFAIknfwFrm0z3Y9VnDHGA1CHSifS8KnJuG8oa8c%252BHwhfecpb1dw%252FdQgPeSbsfwlikSFnsJdTz%252FshAYHas8zNNxjHyxVCniq2H73ldK%252BoVsFL%252Bbjj4FZWypjYWotzAny9hDqUR6%252F7hzGPi3WzNVXQybzxncI2earll562MhAL%252FSms9e24yXoCTNUsF2prvVG6EWli0AROahmaSa7tJgkSL%252BMWL0mpIv%252FyOoywLkrGJm4z2oUy99tmXZY7xr0GoyHEEizvlrNWuzp06bFABBbvp9ueFos4TehuHvAzBQw%253D%253D%7Campid%3APL_CLK%7Cclp%3A2047675&epid=27053854069) wouldn't create any problems with the wiring or the fuses, right?
  14. Well, I need to replace the entire headlights, not just the bulbs and I am concerned that the wiring would support that.
  15. Guys, I need to replace a headlight on my 2009 Edge LTD. The wife had an unfortunate encounter with a buzzard and the left headlight didn't survive it. I'm planning to replace the original ones with LED-equipped ones. Are there any issues with the wiring known? The new light are plug compatible. Is that good enough?
  16. Guys, Got a FORD 6-disc changer for sale (9T4T-18C815-GB). Came out of a 2009 Edge LTD, Microsoft sync, subwoofer, steering wheel controls. Works perfectly fine. Any interest before I offer it on eBay?
  17. Guys, I have 2 of those for sale, complete with center caps and working TPMs. One is in excellent condition, the other one has some slight blemishes on the edge. They came from a 2009 Edge LTD. Anyone interested?
  18. Sorry, had no idea, thanks for making me aware. Maybe one of the admins could move my post over? Thanks!
  19. There is a classified section? Where?
  20. Guys, I need to repair a deep scratch in the rear plastic apron. Does anyone know of some kind of black plastic filler or spray to cover that?
  21. Guys, I have 2 of those for sale, complete with center caps and working TPMs. One is in excellent condition, the other one has some slight blemishes on the edge. They came from a 2009 Edge LTD. Anyone interested?
  22. Thanks a lot for the detailed response. I ordered an antenna from that company.
