EDST777
Everything posted by EDST777
  1. unless such filter is possible, after all there has to be a FL-400 filter? It is admissible?
  2. I noticed cooling liquid of red color here! Probably it is admissible?! Your thoughts as far as it is bad?! thanks.
  3. EDST777
    P1299 Trouble code
    Hello, and in what way you watch mistakes? You have a device or you looked at the dealer on service? Thanks!
  4. Friends. I met the filter on aliexpress , is specified, what it is established on ford EDGE, means perhaps someone changes it? It is seen very not simple procedure!
  5. Yes, you are right, I spoke about it! Thanks for the answer. Really nobody was inspired by this idea? thanks.
  6. On the basis of it http://www.jcwhitney.com/2007-2014-ford-edge/replacement-steel-direct-fit-fender/p3038540d17746y2007-2014j1.jcwx it is possible to think, what fender on 2007 and 2014 identical therefore it is possible to make face lifting having replaced forward part and headlights?? It is the truth?
  7. somebody knows about what I ask?) It something impossible?!
  8. http://shopotam.ru/catalog/221413306471-item.html about what you tell this that?
  9. FORD EDGE 20 CHROME WHEEL SKINS I need one such, please help!)
  10. hello. You can show images of such covers how they at you look? On forward seats and back seats. Thanks.
  11. Hello! Happy New Year!) I have the same problem (I attached images of a door and a torpedo). With what paint I can paint, options? I am afraid that it will be difficult for me to ship the specified paints! I live in the Urals. I wish to correct it beautifully. My prospects?) .Thanks.
  12. at me the same a problem with patches of light!... if to tighten a carbonic film?
  13. 3-4 minutes, further I begin the movement with a speed of 20-30 km/h, in seven minutes the engine gets warm to 90 C.
  14. Hello. My roof of Vista Roof from glass well opens, but began to be closed badly, and now it remains open approximately on 10". I did initialization several times, it doesn't help, the electromotor doesn't have enough force to close a roof. Thus there are no outside clicks and sounds as some write. Simply it isn't closed, there is no force. Having read about the possible reasons here http://www.justanswer.com/ford/4yiio-ford-edge-2008-ford-edge-vista-roof-will-not-close.html http://www.fordedgeforum.com/topic/2327-issues-with-vista-roof/?hl=%2Bvista+%2Broof+%2Bproblem&do=findComment&comment=24760 I hope to lubricate runners (rails). Somebody can specify on the image where and how it is better to lubricate? What lubrication I can apply? There is enough WD40 lubrication or something on a litol? I very much wait for your councils, the winter goes. P.s: I closed a roof very well pushing it into place, I it helped a t.a. At the end of the way it began to move better. Maybe someone will prompt other reasons and methods of elimination, I hope for you guys.
  15. Prompt the general gears, units on Explorer2006-10 and EDGE2006-10? I heard it transmission and that is concrete: RDU, PTU, can still any gears? Thanks for any help.
  16. Excuse for my scrupulousness) in this question, but I have not enough information, important for these technical works on change fluid PTU and RDU (rear differential). I looked for such information at other forums and found out that there is absolyuno an identical question, but on it also there is no answer))). I had a thought: change fluid PTU and RDU and on Ford Explorer or Lincoln MKX can be similar, after all they have an identical PTU and RDU device? Maybe on them there are detailed reports step by step? Thanks for any help. http://www.cargurus.com/Cars/Discussion-t39706_ds553934# windlake answered about a year ago Here is the pic for Trans hoses, I don't know which one is the trans cooler hose. Could you please help me out? And it seems very hard to take them out. Any special tools are needed? I plans to work on it this weekend anyway. If I can't figure it out, I will do the way you mentioned above, repeat 3 times. I am looking forward to hearing from you for your more valueable advice and provide more once I am done. (I am thinking to make a vedio to record everything I do and post it on Youtube for those people who need it. Changing trans fluid is only part of them, I also want to do changing break fluid, power streeling oil, coolant fluid, seaform my engine and tire rotation). I also want to change differential fluid for Front and Back, but have no idea how to do it. I will continue to do the research and hope can make a series to help people to do their DIY. Again, THANK YOU, David and wish you have a nice trip. 3 out of 3 people think this is helpful.You think this is helpful.
  17. Hello. I want to do fluid PTU and RDU change as it is told by the experienced user of the EDGE car in points 2 and 3 ( http://www.fordedgeforum.com/topic/12749-normal-mpg/?do=findComment&comment=112443 ) : Posted 08 May 2014 - 11:28 PM More involved work would be to 1) change out the transmission fluid, 2) change out the PTU fluid (probably thick and gunky by now), and 3) change out the RDU fluid. If you are a handy mechanic, you can do this yourself, but probably less of a headache having a trusted shop do it for you. but I would like to find the complete and exact description of these events, it is desirable with pictures, whether it is possible to see it at this forum. I found similar information here: http://www.fordedgeforum.com/topic/10914-ptu-leak-failures/page-2?hl=+change%20+rdu%20+fluid , but there can be I will be able to find still any more detailed step-by-step information in other posts or video? I didn't find absolutely any information on change of fluid RDU. I badly looked for? Help me and specify where it is possible to it , is possible to read at a forum it? If it is possible with pictures. p/s: At present offer me for change in PTU and RDU the following oil : picture 1,2,3 whether it is normal, after all there are no Ford XY-75W140-QL/WSP-M2C197-A and XY-80W90-QL/WSP-M2C197-A admissions? Thanks for any help.
  18. Friends, there can be someone knows what starting (Amps) current of a starter on Ford EDGE 2008? The matter is that on numerous sites on selection of batteries starting current of the battery 800 A is recommended. I think that this starting current of the battery with a stock and it is higher than starting current which is necessary for a starter. But what starting current of a starter, it is interesting, I didn't find this information in a manual?
  19. Hello. Friends, my battery died, I am going to do replacement. Now (my dead battery) at me the battery 74 Ampere hour, it worked three years, a driving for 93% in the city therefore a constant small charge, I think. The manager in autoshop offered me the battery 115 Ampere hours. Help me council, whether I need to ship 115 amperes of hours or nevertheless to ship new 74 amperes of hour (that will be lower at cost). Thanks.
  20. Hello. Guys, whether somebody knows it is possible to ship somewhere such tuning, how on the picture (plastic on arches)?
