I think they switched over to plastic covers starting in 2011. Not a weight savings measure apparently. On other cars where they have done this, the plastic stuff weighs MORE than the aluminum ones. 2011 2010
Did wrapping them in cloth stop the squeaking/screeching? -
HVAC Blower not blowing all the time
WWWPerfA_ZN0W replied to Mustangfreak's topic in Interior, A.C., Heat, Interior Trim
I had this happen before finally the fan motor gave out. Not to say this still couldn't be the resistor, though, that's the difficult part. The TYC fan motor from Amazon or RockAuto is a fairly low-priced DIY-install part. A bit noisier than Motorcraft, but apparently blows more air as well. I remember at least one person having the resistor being the issue, seach the forum for "blower resistor", should get a hit. -
Great list I WOULD have added a Step 10.5 to first add Motorcraft or cheapo 75W140 to carry away any remnants of brake cleaner/minerals spirits, driven around 50 miles, then final change to Step 11. BUT, interested in your findings, and good luck!
akirby merely stated his opinion, you don't have to accept it. By no means was it "trolling".
Good to know, thanks for the update!
The TB listed for the 16 Edge 3.5L on the Levittown site is AT4Z-9E926-B.
Well, I think you have to replace the tire(s) if you want to correct that situation (unless they are non-directional and can be flipped), get an alignment done to correct the camber/toe, and replace the shocks to correct the SAS issue.
Shocks & struts don't directly impact camber & toe. But they do contribute to suspension geometry, which changes as you drive (more so on turns, bumpy roads, etc). Having properly functioning shocks & struts at that time will help the suspension geometry to work as designed. People lower their vehicles all the time, using the same shocks/struts they had before the change. But this changes suspension geometry, and also the resultant stresses on the shock/strut. This additional stress can decrease the life of the shock/strut, if the alignment does not adjust for the change in suspension geometry. Hence the need for an alignment in this case. If the geometry changes are extreme enough, you can add additional suspension geometry capabilities by using camber/caster plates, adjustable lower control arms, camber adjustment bolts, etc. Are you eyeballing the camber/toe on the rear wheels, or do you have an alignment sheet to work with? http://www.santafegarage.com/precision-alignments/camber-explained/ http://www.superstreetonline.com/how-to/chassis-suspension/htup-0712-camber-101-honda-camber-guide/
If this is the line you need, here is how to replace it 2010 Edge Power Steering Pump to Steering Gear Pressure Line.pdf
This kit might be what you need: 8T4Z-3A719-A I believe the Gates equivalent is this part: available from RockAuto, not sure on whether the banjo bolts are included in this price or not.
How to Change Rear Wiper Blade?
WWWPerfA_ZN0W replied to hanoscf's topic in 2015+ Edge & MKX Generation II
From our very own macbwt -
Need a clear window into the evaporator's operation, so we can watch it freeze up
2011 Edge/MKX My Touch and Sync Problems
WWWPerfA_ZN0W replied to akirby's topic in Audio, Backup, Navigation & SYNC
You can plumb the lines to add gauge pods, or you can load up Torque Pro or ForScan on a smartphone (ForScan also on iOS), connect to the OBD II via an adapter, and get whatever data you want. The Torque/ForScan route is more appealing to most people. If you proceed with an actual gauge install, you will need to find the reference line for boost, as well as a place for the gauge to reside.
Probably involves pulling the dash to get to the thermistor? Then yeah, set aside a good 8 hrs for the first time you do it ...
Hmmm. Possible that this is an "extreme" situation/scenario. Maybe it is by design, kinda like paper shredders that have thermal overload protection. They will time out for a while, maybe 15 minutes, before they can be used gain. The A/C can cut out by design during WOT acceleration, to give full power for acceleration. Ok, the FSM states (note the statement in bold): So possibly 1 or more conditions creating the scenario you have described.
Do you see water dripping out onto the driveway after you come to a stop, having used your A/C? If not, then there is either a clog or the evaporator is freezing over from some other restriction (like a cabin air filter/screen). If it's bad enough, it will eventually throw water into the interior of the vehicle, and/or generate sloshing sounds. Potential for blower motor destruction in the process. Do both fans run when you run MAX A/C on max airflow? Has the system been checked for charge and leaks? Have you cleaned out the condenser that sits in front of the radiator (also contains the trans cooler)? Yes, there IS a control module, it is called the EMTC instead of the EATC.
As demonstrated by FordTechMakuloco:
Not much air coming from vents
WWWPerfA_ZN0W replied to lemmy999's topic in Articles, News & Reviews
Good to hear (no,not about the Fanta), and, fingers crossed Did you go with a Ford/Motorcraft replacement, or a TYC brand, or ...? -
Cost with new OEM parts would probably be way over what it would have cost to purchase new with option. Maybe you can find something in the junkyards to fit. Otherwise you will have to find an aftermarket solution (the pre 2015s may not work), or devise your own. Try contacting Stabilus, they make Powerise units for a lot of manufacturers, may have a solution for you. Also try these guys: http://www.strattecpoweraccess.com/powerliftgate.html
Ouch, sorry to hear! Did they then fix it?
