For doing the 3-time method, no hoses need to be removed, that's the whole point! Just remove the transmission drain plug, drain, reinstall plug. That's it! If you were FLUSHING the transmission (not necessarily recommended), then you'd have to deal with hoses & such. The 3-time method gets you pretty close to a 100% fluid replacement, which is what you want. It is recommended by a trustworthy Ford tech (thirdgenlxi). The location the plug is in a pic in the #19 post in this thread http://www.fordedgeforum.com/topic/2040-transmission-fluid-replace/?do=findComment&comment=97281 and explained in #20.
Thanks for the update! The cycle is starting a little late in the year though, isn't it?
You woulda thunk a CTS would outpace the Edge in performance at least. Interesting.
Great relationship, business the way it should be
If you wind up being happy with the dealer's work & attitude, please consider posting up their info so others can be helped
Would be nice if these results hold over time!
There's no set interval for MAF cleaning/check. If you want to be preventive, since you are running a K&N, maybe do it every 30,000 miles (normal filter change interval)? Definitely do it shortly AFTER you clean/oil the K&N just in case any excess gets stuck on there. IMHO.
Wheel gap needed some closing for sure
I hope not, but I pray for reunion of family, unharmed.
Very, very nice!
How many miles/kms, Thomas? Did they mention a warranty with the service? No "parts" were apparently replaced, but at least the issue is on record, providing leverage for lowering the TSB cost if it does need to be performed.
City driving is going to be tough on mileage, no question. You should be getting somewhat better, if you don't accelerate hard all the time, unless you have no chance to go easy on the gas between lights. I think you'd qualify for severe duty service intervals. So spark plug replacement was a good idea. You mentioned transmission fluid in another thread. Once you get the Mercon V in there, hopefully you will see improvement in transmission behavior, and quite likely mpg as well. I'd also consider changing out the PTU and RDU fluids as well.
Welcome to the forum, Tom, and congrats on your Edge! Would love to see some pics of all your rides, quite a stable you've got going there!
Sounds like the problem has been correctly identified, bokes! Hope they get the Edge fixed up ASAP. Interesting this is not an issue on 2007-10, so must be a design change on 2011+ ...
The PTU (or PTO) exists only in AWD vehicles, so yes, AWD issue only.
How many gallons of coolant, and where is the petcock?
WWWPerfA_ZN0W replied to briandye's topic in 3.5L
Tow package or not? Same coolant, 1 quart more for tow package setup. Get 4 gallons of the coolant (50/50) or 2 gallons unmixed. Engine coolant 11.7 quarts (11.09L) Motorcraft Specialty Green Engine Coolant VC-10-A (US) CVC-10-A (Canada) / WSS-M97B55-A Engine coolant–with trailer tow package 12.83 quarts (12.14L) Motorcraft Specialty Green Engine Coolant VC-10-A (US) CVC-10-A (Canada) / WSS-M97B55-A Type should be listed on the overflow bottle cap, I think, just to verify. Petcock is on the lower driver side of the radiator. http://www.fordparts.com/Commerce/PartDetail.aspx?n=5XXO8s48F4CfMMC8wznJKg%3d%3d&id=287852984&m=2&search=true&year=2009&make=Ford&model=Edge -
If you are not currently experiencing any problems, don't worry about remaining "yellow" mixing in with the "red" fluid. Do the 3x exchange with the "red" fluid, make sure there are no metallic particles in the fluid you drain, and you should be good to go as far as fluid is concerned. For the 2008 Ford Edge, you should be using Mercon V, not Dexron anything. Pg 325 http://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/08edgog1e.pdf Automatictransmission fluid 10.0 quarts (9.5L)3 Motorcraft MERCON V ATF XT-5-QM / MERCON V Rear differential(AWD) fluid 2.4 pints (1.15L) Motorcraft SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL / WSP-M2C197-A Power Transfer Unit (PTU) fluid (AWD) 12 ounces (0.35L) Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant XY-75W140-QL / WSL-M2C192-A
Glad you haven't exactly "gotten rid of" the Edge Great summary of your experiences, Sync has been a sore spot for many, a black spot on a white shirt if you will. Congrats on your new ride of choice, looks great. Wish they'd give the diesel engine option to the Edge, but I think EcoBoost is the big push at Ford, now with AWD as of 2015 MY. Getting above rated mpg is awesome! Which MINI do you have? Pics?
One of your supplier choices: http://cd3performance.com/Ford-Edge/FE-Exhaust
Nice find! Dyno chart here; http://www.knfilters.com/dynocharts/77-2583_dyno.pdf For the 2007-10 Edge (assuming MKX also): http://www.knfilters.com/dynocharts/77-2574_dyno.pdf
Looks like I'm at the limit for gallery uploads, so I have to attach these image files instead. A couple of views of the wiper arm attachment point, a view of the wiper blade attachment point, and a comparison of the old/new blade (WW-1412). No trick really, just requires some steady force if not using a tool of some sort. Fairly simple to do a refill also.
Paul, I think you need a min of 5 posts to use PMs. Go here http://www.fordedgeforum.com/topic/11866-test/ and make 4 more posts to get to that 5 count.
- 7 replies
- short block
- pistons
Wiper blades?
WWWPerfA_ZN0W replied to Bryan003's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Regardless of which product you go with, keep the blades wiped down, as they tend to gather all kinds of dirt & grit that end up scratching the glass. That then makes visibility poorer than it needs to be.
